160w ot 130w (1 Viewer)
Jun 22, 2011
507
1,305
Onchan, Isle of Man
Carthago
Since Nov 2010 after 25 yrs under canvas.
Quick help please
We are getting our new van next week. When we signed for it a year and a bit ago we paid for a 160w solar panel. Now the dealer tells me a 160w panel won't fit but a 130w one will.
He claims the difference is minimal and we won't notice.
Is he right?
Thanks in advance
68c
Oct 22, 2019
1,822
2,805
Southampton
2001 Pilote 270
Since 2004
Could they fit two smaller panels totalling more than 130W?
Reactions: f6c
funflair
19,444
30,629
Guisborough
MORELO palace
since 2012
The difference in performance will be 30w or a little over 20% reduction, I don't know what controller they were fitting but if just PWM you could recoup most of the loss by having a MPPT instead.
Emmit
8,056
17,806
Cornwall
Pilote Explorateur
Jan.2014
Ask him to show you why, in his view it would fit.
I doubt if any single panel under 200w wouldn't fit on the roof of any van (including PVC'S)
Manxcat
Jun 22, 2011
507
1,305
Onchan, Isle of Man
Carthago
Interesting. This is a Carthago compactline i138. I can't unfortunately go and see it as I am on the Isle of Man. We collect it next Friday.
Apr 24, 2018
902
4,050
France
2001 Hymer B544
Since 1992
It sounds like maybe a little bit of laziness on the part of the dealer. Their tech has maybe selected a space on the roof, worked out the max size of panel that will go in there and then maybe run the cables and created a cable gland in preparation. Then (just a guess) maybe they have found that someone has messed up, measured incorrectly or not allowed for the mounting frame, or a mount would be on a seam etc - and thus it won’t fit, so they have selected the next size panel down.
If you want to know for sure, you can ask outright if this is the case, if they come clean, and it’s an honest mistake then there isn’t much you can do. It’s correct that there isn’t much difference and only in very borderline conditions might any difference be noted. 100, 120, 150, 180W, it’s all still quite low peak power. Some have suggested that an MPPT controller would make up the difference and that’s true - I would ask the dealer to make it right by fitting a more extensive MPPT controller as a gesture to make it correct. The cost to them will be a little bit offset by the reduced panel cost.
Perhaps more interesting, is the idea that you might not be able to fit more than 150 ish watts of solar on a van roof. This just isn’t true. My van is just 6m and has a 1000x600 central elevating skylight, a sat dish, an airing cupboard vent, an AC unit directly behind the skylight, and two further 400x400 elevating vents - one above kitchen and one above bathroom. What spare roof space there is very sparse and broken up. I was still able to fit 6 x 100W panels, all using the corner and side mount mouldings that glue to the roof and also take up space.
raysalaugh
2,286
4,187
Leyland
AT Delaware
since 2010
Actually you will probably need a lot more than 160w panel to spend most time off EHU, on Craig Solar a 130w panel is 10cm narrower
and 15cm shorter than a 160w. Leaving the dealer to their own devices means they'll do what's best for them.
Sep 3, 2012
7,576
26,116
Cheshire
C Class Elddis 175
8+ years
Quick help please
Is he right?
Thanks in advance
The make of the panel also dictates the size which can vary quite a lot by manufacturer
Lenny HB
53,733
151,146
On the coast in West Sussex
Hymer B678 DL
On a 138 you can get a 100w panel each side of the rear rooflight, and probably a 200w across the front of the roof, not sure about the space in front of the rear rooflight.
I would get him to fit 2 x 100w at the rear.
Sep 29, 2007
805
1,167
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
Depending on the type of brackets maybe you could have a bigger panel.
The problem is that many brackets add about 14cm to the length of the panel.
But there are other options that allow you to fit panels without the brackets taking up valuable space.
Edit:
If you go to 1:45 of this video you’ll see the approach we take to use bigger (longer) panels when space is restricted.
3,478
9,236
The salty bit of Hampshire
Carthago Compactline
Since 2017
I have 2 x100w either side of rear roof light and another 100w immediately in front of it. I still have vacant real estate in front of the main skylight which could probably take a 300w panel so you could get a maximum of around 600w on a Carthago 138.
Apr 24, 2018
902
4,050
France
2001 Hymer B544
Since 1992
Here’s what’s possible on an already crowded 6m Hymer - it makes cleaning the roof a bit tricky :)
Lenny HB
53,733
151,146
Hymer B678 DL
Fun cleaning all the green off under the panels.
I always mount mine so they can be easily removed to give the roof a good clean occasionally.
Oct 5, 2021
383
352
Tropical Skelmorlie
Globecar 5.4 Shine
Since 2013
Dealers are definitely not the people to install most things - solar panels included. I know it's convenient, but there are many specialist installers who would do a much better job, and actually give you what you want, instead of what they want. And it would be considerably cheaper.
May 10, 2020
556
1,666
Carthago
Hope you got your panel issue sorted.
My 138 already had a panel fitted when I acquired it at a year old, but I have no idea what the output it is. Seems to work OK and there is plenty of room for a couple more up there. I did replace the controller for a decent Victron mttp unit though.
I'm going to suck it and see if I need any more. So far the combination of not stopping for too long in any one place and a 280a Li Battery has worked fine for me.
Oct 27, 2007
1,826
2,387
Near Dartford
Hymer
When we bought our van 13 years ago we fitted an 80watt solar panel. We have never fitted more. I use a CPAP machine and we can go 5 days in the winter off grid. We don't watch TV or use an inverter.
