12 volt plug (1 Viewer)
May 16, 2014
817
1,063
Ammanford
Dethleffs Trend
since May 2014
Can anyone tell me what type of 12 volt plug do I need for a 2020 Detleffs Trend? Thanks in advance
43,365
49,686
Could be one of three common ones.
Cig socket plug, a DIN/HELLA plug or a dedicated two pin plug.
A pic of the socket will decide.
tonka
10,840
21,556
Cannock, Staffs
A class Burstner 800
Since 2000
German vans mostly use the Hella / Din plugs.
Standard size cigarette sockets are inside the Fiat cab.
mpdcymru
May 16, 2014
817
1,063
Ammanford
Dethleffs Trend
since May 2014
this is a photo of the 12 volt socket. I have a Hella plug which is too big for the socket as is the normal cigarette lighter type
Bustup15
1,492
3,735
Durham
Dethleffs I 7820-2
New to motorhomes 2019
2019 Dethleffs used Hella in the hab area and conventional in the Fiat cab area
mpdcymru
May 16, 2014
817
1,063
Ammanford
Dethleffs Trend
since May 2014
It does look similar but mine is labelled as 120 W whereas the one in your plastic is labelled 10A. I know exceedingly little about electrics!
Looks like a hella socket to me? But is the CBE 12v socket different and the reason your current plugs dont fit?
CBE 12V so
43,365
49,686
Change the plug on the TV lead, don't bother with an adaptor as the sockets on them are very poor quality.
That's the problem I think Lenny, the OP doesn't know what the socket is to buy the correct plug.
OP beat me to it.
Lenny HB
53,615
150,681
On the coast in West Sussex
Hymer B678 DL
That is a Hella plug it will plug straight in, the one John referred to fits a standard cigar socket with the red bit on & a hella without it.
mpdcymru
May 16, 2014
817
1,063
Ammanford
Dethleffs Trend
since May 2014
Thanks Lenny (and others) I was just being too gentle with the plau - it just required a bit more wight behind it!
EMS
Jan 8, 2010
200
181
Hants Sussex border near
Coachbuilt Low
Started 2009!
Take care fitting the plug as it can short out and cause the fuse to blow, I speak from experience!
There was not enough light to see the socket clearly in the evening light when we wished to watch TV.
