.07 amp drain nothing switched on (2 Viewers)
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
o/p here
Ive just gone to check the battery as discribed above, Ive got two batteries, I pulled fuse on the first one and it has melted and blown, I checked the ampage draw on the PANNEL it had changed to .4amp and th voltagwe had gone ujp to 12.6 (was 12.4 with blow fuse in ) I replaced the blown fuse with correct size, I checked the pannel again the ampage draw is now steady at .3amp (which seems to be in line with other scout owners).
I put the charger on whist I type this, what next pepole?
Doesn't make sense, then should be any difference between a blown fuse and no fuse at all.
I would recommend removing the fuse again and measuring the voltage on each battery while they are isolated from each other.
Connecting two batteries together that are at differnt stages of discharge can lead to very high currents indeed.
Gordon
Scout
Scout
3,960
122,018
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
Gordon
quickly runs outside to check:Eeek:
43,371
49,742
o/p here
300ma is still very high.
it equates to 50.4amps per weekand a pair of 85ah batteries will be flat (50% discharged) in around 10 days. :Eeek:
Nov 14, 2009
425
252
normandy
c class
16 years
hi sc 05 out sorry for my hijacking!!
in your battery locker you should have two fuse holders, one for each battery. if you pull the two of them out does your cd/radio work or does it stop like mine?
Scout
Scout
3,960
122,018
South Yorkshire
chic c line
I take both batteries out and there on the floor, fuses pulled, the one with the blown fuse had blew the new fuse, but this is not supprising when I checked the voltage on the batteries, the good fuse one is showing 13.51 volts, and the duff fuse one zero which is why it blew te fuse trying to pull too much current in?
I suppose a pair of new batteries is in order tomorrow.:Sad:
43,371
49,742
and there lies the problem of the blown fuse.....one dead, one trying to transfer charge to it.
for the slight difference in cost i would go for 110ah if they'll fit.
Scout
Scout
3,960
122,018
South Yorkshire
chic c line
no worrys mate, it just got a bit confusing for our helpers dealing with both of us.
Yes it stops, so the radio is defo on the had side:thumb:
Scout
Scout
3,960
122,018
South Yorkshire
chic c line
sadly no they wont, shame becase when I went to get gas today my caravan had 110's on offer
43,371
49,742
as in my previous post....my radio was pulling 190ma with the radio turned off, or so i thought...it was just in standby mode still drawing power to the main circuits except the amplifier circuit which is the power hungry bit when turned on.
once i sorted a switched main supply the memory supply dropped to just 9ma
Nov 14, 2009
425
252
normandy
c class
16 years
surely your battery locker is the same as mine? i have two banner energy bull 110 amp/hour batteries in mine .
Scout
Scout
3,960
122,018
South Yorkshire
chic c line
Ive take out the loom to the duff battery
I was going to measure the current draw through the fuse block, but my meter only does up to 2 ampdc?
I took out the fuse, put the neg lead into common on my meter, the poss lead into the 2amp max socket turn the dial to 2Amp and measured accross the empty fuse block, the meter was just flashing 1.0000 which to me ment it was measering too high a draw for the meter to read correctly?
So I put the fuse back in, checked the draw on the pannel .7amp
I went to the fuse distribution block and removed each fuse in turn checking the ampage draw each time, no fuses made a differance, but the light in the power cupboard on a presurre switch makes the current draw drop to .2 amp when it comes ON and goes back up to .7amp when off. This does not make sense to me?
Scout
Scout
3,960
122,018
South Yorkshire
chic c line
whoops my batteries are in the other way round:Doh: I dont know if the straps will fit that way, Im sure I read somewhere in the manual the charger would only DO 2 85amp hr max, but yours seem to work ok?
Nov 14, 2009
425
252
normandy
c class
16 years
yep, my original batteries were on their way out when the van was new!! replaced with 110's and they have been fine ever since. i took the straps out and replaced with a piece of timber along the front of the locker to keep the batteries in place.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
My Truma blown air heating system's fan is wired completely independently of the control panel, as I discovered to my cost when I left it on while the van was in storage and it drained the leisure battery. As the leisure battery is wired to top up the cab battery in storage, the cab battery drained too.
Minxy
32,700
66,732
E Yorks
Carthago Compactline
I've only quickly scanned the posts on this thread as tea is just about to be served up (cauliflower cheese and bacon if anyone's interested!) so my questions is - have you left any lights on, such as in the grill/oven that could be drawing power?
43,371
49,742
your battery charger will charge just about any ah battery.....its the time it takes to do it which is the important bit.
a 10amp charger will take X hours but a 20amp charger will only take half as long or a 5amp charger will take twice as long.
i just charged 6 x 2V 110ah batteries (wired in parallel (12v)) using an aldi 4amp charger.....took three days from totally dead (9v combined voltage)
Scout
Scout
3,960
122,018
South Yorkshire
chic c line
result
::bigsmile:
Just got of the phone to sargent eclectronics, I explained the whole situation and all I had to do was recalabrate the system pannel, the way to do it is, on the pannel over the door select the amps draw option, press and hold the left arrow key, the system will read "recalabrating" and the set the system, release the key and the reading should be zero amps ( if all power is off). I had to do severail times to achive this, this in itself means to me the system is flaky to say the least.
anyway job done Im off to buy new batterys:Angry:
