Does the non-remote key still do the handshake to take the immobiliser off?
Yes, we don't have central locking so I only use the non remote key. If it didn't there wouldn't be much point in having it.Lenny HB Does the non-remote key still do the handshake to take the immobiliser off?
that is a decent price.. and as said they need access to the van to match to the ECULocal key cutter says he'll want £75 and access to the van for an hour to cut me a spare ignition key.
McLouis Fusion 331 2021
Reasonable price?
I was hoping to get one for a tenner or so - didn't realise they had chips in them! Bugger!
But it needs programing to the ECU.Go on e bay there are companies that will cut the key for you from a picture, if you are bothered about it being posted to your address use a pick up box cost between £10 and £15
The blank, with chip, tends to be the cheaper component of the cost with the programming being more expensive. It was in our case.I thought he just wanted a spare key as for release steering etc not driving, there are programable chips from £30 as well so still cheaper but will have to pay to get it matched up
Our "spare" operates exactly the same as the original FIAT one.
I asumed the spare just opened the door, had the van 10 years and never tried LOL
Reasonable price?
iris scanners maybe but not retina scanners, an iris scan is highly accurate, and whilst most biometric can be forged it is unlikely particularly if matched with another biometric such as the volume of space within your ear or a vein print from you hand.Jesus. They'll be creating false eyeballs for retina scanners soon, just from your Facebook photos ...
Wanting to access the vehicle is the worrying bit you can walk in to a car dealer they will make another key and not bother with accessing your vehicle…..it may be a cheap key but…..I recently had a non-remote key cut for my wife’s Kia at Timpsons and that was £75. He used a chip reader to clone it to the existing remote, so no need for access to the vehicle.
Vehicle access for an hour ? Are they scouting your security I’d rather pay a dealerLocal key cutter says he'll want £75 and access to the van for an hour to cut me a spare ignition key.
Reasonable price?
But they are not chipped so won't disable immobiliserGo on e bay there are companies that will cut the key for you from a picture, if you are bothered about it being posted to your address use a pick up box cost between £10 and £15
I remember I had a new Ford Sierra came with plastic emergency key that would open any ford of that era.Wanting to access the vehicle is the worrying bit you can walk in to a car dealer they will make another key and not bother with accessing your vehicle…..it may be a cheap key but…..
It does take them about an hour to check the key / ecu, cut the blank, check it for basic operation (ie unlocks doors, etc), programme to ecu and then recheck full operation.Vehicle access for an hour ? Are they scouting your security I’d rather pay a dealer
Apologies Dane as just reread my original response to yourself and I guess you could read as it also disables the alarm. It doesn't when unlocking the doors!Just been up the van the spare blank key opens the door but the alarm kicks in, which is obvious I suppose. They blank key starts the engine ok if I open with the central locking fob, so for me a remote key is necessary.
In an emergency I think there is a convoluted way of dissabling the Autowatch alarm/immobiliser if needs be.
I very much doubt they would do that without showing proof of ownership otherwise any scroat could get one .Wanting to access the vehicle is the worrying bit you can walk in to a car dealer they will make another key and not bother with accessing your vehicle…..it may be a cheap key but…..
That's handy to know for the future, I will give it a go, I hope it works.Apologies Dane as just reread my original response to yourself and I guess you could read as it also disables the alarm. It doesn't when unlocking the doors!
Don't have the non-fob key with me but try unlocking the door with the metal insert key and open the door. This should activate the alarm however if you put the same key in the ignition and turn to "MAR-ON" it should disable the alarm and turning it again should start the engine.
Not ideal as we'd get a call from our tracking folk but .....
