Your best guess please (1 Viewer)
Top Hat
375
622
Durham
Van Conversion
8years
This year I will be having extended trips abroad.
Could you give me your best guess on how long a 6kg gaslow refillable bottle would last used ONLY for hot water and cooking.
My past vans have had 2 11kg bottles and all appliances running on gas, so I have know idea.
Charlie
Top Hat
Top Hat
375
622
Durham
Van Conversion
8years
No problem, fridge is 12v only and heating is diesel.
GerTee
405
4,199
Near Fareham
Burstner iXeo
Since 2016 - UK & Europe
Hi Top Hat we have 2x 11kg gaslow bottles in our Burstner. Spent 4 months in Europe last year and found that 1 bottle would last approximately 5 weeks. We used it for our fridge,cooking and hot water and seldom had access to EHU so it did pretty well.
Emmit
8,025
17,697
Cornwall
Pilote Explorateur
Jan.2014
Me and @GerTee sort of agree.
We spent Autumn at Mo's place and I reckon we used about 6Kg's in about three weeks (but that would have included the fridge)
Apr 11, 2015
5,396
54,849
hull
Laika Ecovip 300
Depends when you go and what sort of cooking you do. We have gas cooker, use gas to boil the kettle, gas only water heating, and fridge when off grid, oh and cadac. Do use the oven and also grill for toast. lasts 5-6 weeks. frotunately have 2 bottles and refillable bottles.
138go
3,276
14,613
Carthago 138
Since 2001
Is this like one of those Summer Fair questions where you have to guess how many currants are in a cake. It's impossible to know so best guess would be about three weeks but it could be longer or it could in fact be far shorter. A lot of course would depend on the weather and what sort of meals you are cooking as well as how many hot drinks you make during any given 24 hour period. It would also depend on how many hand washes and showers you took in the same period. Being in Europe would also mean taking into consideration the altitude and of course how hot it was as it will take less time to heat water that is slightly warm than water that is freezing cold.
If its a refillable whats the problem just get some more ..
Mar 23, 2012
9,520
31,906
sleights
c class
Yes fill up when you get the chance we did last time in France their fittings to fill seem to me a lot better than ours
Top Hat
Top Hat
375
622
Durham
Van Conversion
8years
Fridge is supplied with 12v from which batteries? How big are the batteries? How long do you intend to be parked?
300 a/h battery bank with 220w solar,
the fridge is fed direct from the leisure batteries.
If I was forced to guess 3 week + would have been my guess.
Nice to get a guess from someone who's done it.
Jaws
23,828
72,281
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
If you boil a kettle for hot water rather than the water heater and you are only using the gas for cooking, my guess would be 3 to 4 weeks.
A bit less if you use the water heater ( because you are heating up 10 litres of water each time, not just what you need )
Minxy
32,621
66,438
E Yorks
Carthago Compactline
I'm drooling here!!! :D
Feb 22, 2014
2,107
10,269
Grantham
Rapido Le Randonneur
Since 2015
When are you going....why not live in your van and use it as you would abroad. Then you will know for sure!
Riverbankannie
10,491
61,361
Bristol
IH 630 RL PVC
When we used to travel with friends in VW sized campers, one 3.4 kg calor bottle would last at least 4 weeks. This was using the gas for all meals every day 2 rings and the grill, and lots of cups of tea. We boiled the kettle for washing rather than fire up the water heater. We stayed mostly on sites as friends had no on board facilities. We used the fridge on gas for about 5 nights of those 4 weeks and every time we stopped en-route for lunch or look around.
Our friends lasted about the same.
So my best guess is that a 6kg bottle will last about 8 weeksif not using it for the fridge at all.
Top Hat
Top Hat
375
622
Durham
Van Conversion
8years
I have a construction/civil background (belt and braces) hence the question about gas wondering if I should get another bottle :rolleyes:
Riverbankannie
10,491
61,361
Bristol
IH 630 RL PVC
The best thing about having a refillable, which we now have, is not having to worry about changing bottles. We keep a look out for garage chains that advertise lpg on the forecourt and when the gauge is reading about 2 dots (7/8 of the way down the dots!) it’s about half full and we fill up at the next opportunity without going out of our way.
The most unreliable part of the system is the gauge!
two
Aug 4, 2011
4,901
4,571
West Midlands
A-Class Fiat
If you know how long an 11Kg bottle lasts you, assume that a 6Kg one will last at least half as long.
Mar 23, 2012
9,520
31,906
sleights
c class
Unless you are a certain well known Labour politician in which case it will be between 10 minutes and 6 months
Feb 20, 2010
477
855
winchcombe
swift sundance 630g
We used 1 bottle 6kg in 4 weeks that was cooking only as was on ehu for fridge and hot water boiled with kettle,and on site showers.
138go
3,276
14,613
Carthago 138
Since 2001
Just take a Calor Bottle with you. If you run out switch over fill up and switch back again. LPG is readily available you just need the correct fittings. Don't expect the Filling Station to have them. Some do and some don't.
Top Hat
Top Hat
375
622
Durham
Van Conversion
8years
Yes I will have a full 3.9kg emergency back up Calor gas bottle to do just that, and all the available fittings (y)
9,363
24,696
Derbyshire
Elddis Accordo 105
since 2014
If you paint a 5L water bottle black on one side and insulate the other side, then fill it and face the black side to the sun, you get free hot water. :cool: works very well in Spain.
I'd have thought without using the fridge the gas would last months. Depends how much you cook though.
suavecarve
7,518
38,876
Surrey/Hants
Rollerteam 685
July 09
Why is everyone guessing ?
The answer is 42 ....... days
