gerry mcg
Quick question.
I'm wiring in a victron smart battery BT voltage and temperature sensor.
The wiring is simple and pre fitted A fused red live wire with ring terminal and a black ground wire with ring terminal.
I have a Victron BMV700 Shunt fitted.
Common wisdom is all grounds come off the negative terminal of the Shunt.
Does this apply to the victron Battery Sense too? Or should it be connected to the negative terminal of the battery (as it is reporting the battery temperature? (How does it do this? Is it simply reporting ambient temperature in the vicinity of the battery by direct contact of the smart sense unit? Or by some form of electrical sensing via wires?)
I guess it is not critical as the power draw of the BT is negligible
And secondly if it should be directly wired to the battery, as I have 2x95Ah batteries, should I wire it across both or simply to one?
G
G
