DaveS
- Jan 2, 2012
- 117
- 48
- Knaus Van Ti 640 MEG
- Had a variety of tents, tipis, motorhomes, caravans and now back to a coach built motorhome!
Didn’t even know that was a thing.. so I shall go and read up!Have you considered an inverter with a pass through facility? Check out the Renogy inverter YouTube videos. I have a 3kw Renogy inverter and am really pleased with it. There are some people though who have had different experiences with Renogy inverters
, is it reasonable to wire in the inverter output in to the 240v consumer unit along side the hookup input?
Ok understood! And yes obvious when you say it!Not directly. Your inverter will make the hookup pins live if simply doubled up. Bad very bad.
You need to go through a changeover switch. One way for hookup the other for inverter.
That sounds like what I’m after.Ours is wired to just the 230v sockets with a manual switch for EHU/OFF/INVERTER
I completely agree with this.If you don’t have aMultiplus (or similar) you’d need to wire in a changeover switch. Don’t go for a cheap toggle switch, go for a decent rotary switch.
Then you will also need to take into account the fridge and mains charger (don’t feed into them from the inverter).
Any links to anything suitable?I completely agree with this.
DaveS Look for ones with 3 ways. So you have an OFF in the middle. Some of the cheaper switches can cause problems if you just move from 1 to 2 for instance. Also the 3 way changover will allow you to isolate the van supply without unplugging stuff.
Look for something like this. I am not recommending this one specifically.Any links to anything suitable?
That’s great, gives me an idea of the sort of thing we’re talking about.Look for something like this. I am not recommending this one specifically.
But with a 3 phase switch you can also do the disconnecting of the inverter output to prevent backfeeding amongst other things.
Raul may be able to recommend a specific product. Been a while since I last did one like this sorry.
For simple single phase this is fine.Any links to anything suitable?
Thank you so much.For simple single phase this is fine.
We‘ve installed loads of these into Motorhomes and they work really well. You don’t need to change over the earth, simply join them all together.
I use the 3 phase one so I can disconnect the output of the inverter to prevent backfeed and generator. I can't remember the details now but the 3 phases did allow some extra features that you cannot do with a single phase change over switch.For simple single phase this is fine.
That is the way I did it in my own van using a Victron Multiplus.I fitted a 2000 watt Renogy with built in automatic changeover switch that works perfectly, no external changeover switch required. I also bought a Renogy dc to dc charger which failed in a few weeks and they were a nightmare to deal with.
So does that power everything from inverter or just sockets?I fitted a 2000 watt Renogy with built in automatic changeover switch that works perfectly, no external changeover switch required. I also bought a Renogy dc to dc charger which failed in a few weeks and they were a nightmare to deal with.
Power’s everything but I switch off the chargerSo does that power everything from inverter or just sockets?
I changed the wiring on my motorhome so that the water heater, the microwave, kitchen socket and one additional socket all work through our Renogy 3000w inverter when there is no EHU, it automatically powers them on 240v via the pass through facility when on EHU. It was relatively simple as I just identified which the circuits were, removed them from the consumer unit, put standard 13A fused plugs on and plugged them into the two UK sockets on the inverter.So does that power everything from inverter or just sockets?
Fitted a battery master as well as if you bypass the mains charger and the victron takes over you won't be charging your cab battery.
