I 100% agree with this. I was replacing mine every 2 years.I always use Bosch Aero blades. I found cheap ones tend to go hard in no time so false economy.
Mine on my 09 van are the same as thatThat strange I’ve just ordered a pair just under £20 , bit dear maybe but the ones I have on my fait 2019 never seen before.
They have a little square button that you push to release old ones ,
Never looked before and thought they would be hard to find but was quite easy to find.
Are they all like this type ?? 26”&22”
That’s what I do but not the foam. Just put the wipers in front of pedals, or on drivers seat.I always remove my wiper blades between trips.
Stops them getting aged by sunlight, or sticking to the screen and tearing if used after being left stationary for a long time.
Just make sure to put foam or similar under the arms so they don’t damage the windscreen.
Not sure if we are at cross-purposes here?That’s what I do but not the foam. Just put the wipers in front of pedals, or on drivers seat.
I use Bosch Aero Blades on my car and motorhome. They work well and last.Hi
I’ve got to replace the windscreen wiper blades on our RHD 9 series Fiat Ducato, but I’m not sure which would be the best replacements. Any suggestions please?
Thanks.
No. I understood youNot sure if we are at cross-purposes here?
I was suggesting foam under the ends of the metal wiper arms after the wiper blades have been removed. Just in case the wipers are inadvertently operated and the arms leave two arc-shaped scratches on the windscreen.
