What is the cost of fitting WiFi is it possible to fit it myself
I fitted mine myself. I fitted a netgear nighthawk 4g router. This has external aerial sockets. So I also have a roof antenna (Poynting). I think the roof antenna is important to get a signal even if its fairly weak. If not fitting a roof antenna you may as well use a phone hot-spot in my opinion. It's great having permanent built in Internet. Everything remembers it and just works. I have cctv and remote Victron monitoring thanks to the permanent internet connection. So glad I fitted it. 5g is more expensive but 4g is good enough for streaming netflix.What is the cost of fitting WiFi is it possible to fit it myself
The first part of that question is a bit (a lot) open ended.What is the cost of fitting WiFi is it possible to fit it myself
That is only CAT4 probably won't work as well as a modern phone.The first part of that question is a bit (a lot) open ended.
A bit like what is the cost of buying a motohome
The second part is a lot easier. Try starting with something like this - just put a SIM card in, charge it, and off you go.
You have fiitted wi-fi.
Somebody will be along in a minute to say - there are much better units than that.
but if you start simple, you will learn a lot.
And it may last you a long time. Ours has.
