Why haven't I got any gas?
Katie George
Suffolk
Autotrail Apache
Hi all,
First time motorhome owners, here's our first hurdle! Connected up the gas cylinder, turned on the gas on top of the cylinder itself. No gas coming through to cooker. Is there something else we need to turn on? There's a yellow tap in the gas cupboard, this was in the vertical (on) position when I connected gas cylinder. It says only for inspection use on it, so haven't done anything else with it. The motorhome is an Autotrail Apache 600SE, 2004.
Katie
You will have the clip / knob on top of the bottle.
Also inside the van, somewhere, there will be seperate isolation valves for each gas appliance and maybe someone has turned those off..
HOWEVER.. IF not used for a while you do need to bleed the air out the pipes so could take a short time for gas to come through.
Make sure you haven’t got a crash sensor system fitted near the bottle, if so press the two buttons (green first) to bleed gas through.
Do you have a Truma securemotion regulator fitted like this.....
If so have you tried holding down the yellow button (as shown on the pic) for 3 seconds?
Pete
If you have the automatic changeover above the bottles you usually have to press the little button on the pipe just above the bottle.
Hello and welcome!
Hello Katie
It would help if you could send a picture of your set-up.
There are many different arrangements and it won't help much to learn about the ones you don't have.
Hello Katie
It appears she sorted the problem about 6 hours ago.
sadly, probably the last we will ever hear from Katie, worst for us is we will never know what actually fixed her problem o_O
Oh,she’ll be back...........we’re irresistible.:D:LOL::p:ROFLMAO::D
