- Apr 6, 2019
- 5,013
- 10,133
- RV
- FourWinds Windsport 6.8L V10
I've been using the wago ones recently theyre really good too. I did make sure to leave a little slack in the wires to allow for some movement Chausson use them on their work. Some others on here prefer soldering and heatshrink but some people say it's not a good idea on vehicles due to oxidation and movement. Another option is crimping but I'm never really sure how tight the crimp is on the wago connectors you can actually see the wire going through the bit that grips the wire so theres a bit more certainty I've bought a few for wiring at home.
Pah, waste of money - everyone knows the best way of connecting cables is to twist them together and cover them with sellotape![]()
Amateur. You're supposed to use Masking tape.
Is it still best practice to strip the insulation from the cable with your teeth?Pah, waste of money - everyone knows the best way of connecting cables is to twist them together and cover them with sellotape![]()
Really? I thought elastoplast was the best thing as it allows a bit of movement!Amateur. You're supposed to use Masking tape.
Nothing you two write will stop me using foilAmateur. You're supposed to use Masking tape.
Don't joke, my late FIL seemed to have a death wish as far as electriciy was concerned. When he cut through his mower cable, the two wires were simply twisted together and "insulated" with fabric elastoplast.Pah, waste of money - everyone knows the best way of connecting cables is to twist them together and cover them with sellotape![]()
I used to do that in my youth, which is why I have a front crown.Is it still best practice to strip the insulation from the cable with your teeth?
I’ve been doing it that way for years and never had any problems.....![]()
I’ve used them, they work well, but as with anything the better quality/higher priced ones usually perform better.I thought it was going to be those ones you put the wire in each end and warm them up with a lighter or small blow lamp and they get soldered and heat shrunk in one. Anybody used them? look good but quite dear.
Yes, just a rival to them i think - slightly more visible connection point so you can look from the side and make sure wire is all the way in.They look like an alternative to the Wago connectors
Wago Connectors | Wago Electrical Connectors | Screwfix
Buy Wago Connectors at Screwfix.com. Join electrical wires quickly and safely. Maintenance free. Trade trusted. Click and collect in as little as 1 minute.www.screwfix.com
Tried some Amazon supplied ones - found them, pretty poor performance.I thought it was going to be those ones you put the wire in each end and warm them up with a lighter or small blow lamp and they get soldered and heat shrunk in one. Anybody used them? look good but quite dear.
£11 for a pack of 40x 3-way at ScrewfixAnd cheap as chips - Perfect for MoHo's
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=254391650511
The 'only' issue with the Waguo ones is that they can come loose - I remember in one of our Globecars we had an issue with the rear lights over the bed which sometimes would work, other times not, I managed to find the cause in the end which was that the wires, although appearing to be fully inserted into the connectors, weren't so only occasionally touching sufficiently to get power, probably once they'd been jiggled a bit from us driving! Its a good idea, therefore to check they are all fully inserted if you start having problems.
The alternative make clear ones look better in that regard as you'll be able to see if the wires are fully inserted without having to mess about unclipping and pushing the wires to be sure.
It might also be the wires were cut a bit short I allowed a bit of slack theres bound to be some movement.The 'only' issue with the Waguo ones is that they can come loose - I remember in one of our Globecars we had an issue with the rear lights over the bed which sometimes would work, other times not, I managed to find the cause in the end which was that the wires, although appearing to be fully inserted into the connectors, weren't so only occasionally touching sufficiently to get power, probably once they'd been jiggled a bit from us driving! Its a good idea, therefore to check they are all fully inserted if you start having problems.
Bu&&er. That's where I've been going wrong. You've got to cover the bare wires? Who knew?Amateur. You're supposed to use Masking tape.
I'll tell the Globecar workers then.just get a competent person to fit them , problem solved![]()
