I'd welcome advice.
Frankie Platin plus. has fancy Buttner solar, inverter, charger, 3 lithium etc.
It intermittently trips the RCD on EHU.
Last year it tripped the campsite in Brugges!.
It's had the Frankia lead drum thing removed and usual blue 3 pin instead. RCD replaced several times. new freezer.
Helpful chap in Luxembourg and local caravan hospital have looked and said was OK.
It has worked well last 12 months.
Worked well 3 nights Forest of Dean.
returning home it repeatedly tripped on connection to house EHU.
Work around was to switch off 12v, re switch RCD, then turn 12v back on and now works.
Some have said it is the inverter sending 240V, so RCD gets 240 two ways. AFAIK the inverted was switched off.
Trouble is am about to go to Alps so need confidence of EHU.
Thoughts?
Thoughts?
