The regular size gas bottles are the same connector as a French one. I believe the gasflow ones fit. However the much better plan if you have a bulkhead mounted reg is to use a bottle reg and connect it through the external bbq point ( especially if you have secumotion)I have a couple of Truma gas pig tails but don't know if they are suitable for the gas bottles used in Morocco. Can anyone (Basildog?) clarify for me?
These are the one that I have (a G7 and a G12):
Interesting, but neither of the pigtails I have suggest that they’re compatible with French bottles.The regular size gas bottles are the same connector as a French one.
I’m struggling to understand why a bottle regulator would be preferable over a bulkhead regulator (which I have) particularly given that I have space in the gas locker to fit a Morrocan bottle. Am I missing something?However the much better plan if you have a bulkhead mounted reg is to use a bottle reg and connect it through the external bbq point
Not good adviceThe regular size gas bottles are the same connector as a French one. I believe the gasflow ones fit. However the much better plan if you have a bulkhead mounted reg is to use a bottle reg and connect it through the external bbq point ( especially if you have secumotion)
Its good advice for Morocco because the gas is quite oily and has killed quite a few regulators, the Secumotion ones seems particularly vulnerable.Not good advice
Not only do all BBQ (gas outlet) manufacturers specifically state that they aren’t designed as an inlet but most bottle mounted gas regulators are single stage and designed for outdoor use only as they don’t incorporate any over pressure protection, they can fail to full bottle pressure .
Far safer to use the correct gas pigtail and operate through the bulkhead regulator.
Sorry but I have to disagreeIts good advice for Morocco because the gas is quite oily and has killed quite a few regulators, the Secumotion ones seems particularly vulnerable.
In using a bottle in this way you would obviously stand the gas bottle outside the vehicle.
bigtwin You would need the pigtails with the French Connector (L/H 3/4 Bsp??) I think I might have one if thats the way you wanted to go let me know and I will check and post it to you. hope you have a great trip Ian,
Who said cheap? Not me.Sorry but I have to disagree
Not sure why you think the bottle outside is going to help in any way ?
Those cheap bottle top regulators are not meant for supplying gas to a leisure vehicle, they can and have failed to full bottle pressure which you really don’t want in a confined space.
Seeing what people have done whilst in Morocco actually beggars belief.
Just because something has been done for years doesn’t make it right.Who said cheap? Not me.
Bottle regulators have been used in Caravans and Motorhomes for years, I bet there are people on this forum with them.
I have to give the correct current information for obvious reasons, open flued water heaters were also used for years but how many students / tenants had to die before change happened.
The same applies to single stage regulators that were changed after lessons were learned.
We hear it every day in the workshop
Bottle top regulators are still supplied on a lot of German vans, Hymer for example, the bulkhead one is an option.Those cheap bottle top regulators are not meant for supplying gas to a leisure vehicle, they can and have failed to full bottle pressure which you really don’t want in a confined space.
Indeed..Bottle regulators have been used in Caravans and Motorhomes for years, I bet there are people on this forum with them.
Exactly what most people do. one of the biggest campsite safety hazards in Morocco is the EHU. We were actually parked next to one where the hab charger caught fire due to voltage fluctuation on a previous trip and on last years trip there was a surge through the campsite which took out several fridges, chargers and other devices. These we saw first hand but lots of similar stories, its a fairly regular occurrence.Indeed..
My PVC has a bottle regulator .. van is 20 years old .. hasn't blown up yet .. and for more years than I care to count we had them on our caravans.. never any problems..
on the other hand, I had to replace a faulty bulkhead regulator on my Hymer..
While in Morocco with the RV there were no places to fill the LPG tank, so I bought a 13kg butane bottle and a regulator and fed into a BBQ point .. bottle stood outside while using ..
that's a fact .. and why I never used it... one look at the EHU outlets , cabling and distribution box was enough for me .. scary stuff ..one of the biggest campsite safety hazards in Morocco is the EHU.
Yes we stock them as like you say many continental vans and caravans use themBottle top regulators are still supplied on a lot of German vans, Hymer for example, the bulkhead one is an option.
German bottle top regulators do have a safety pressure relief valve.
Its the secumotion regulators they tend to kill, others don't seem to suffer as much. Apparently their gas is quite oily (although Morocco is improving all the time). I'm still a long way from plugging into their EHU's though. I have my charger on 3 pin plug so if I absolutely had to I could just plug that in.Okay if you have a Gaslow/Gasit system your best bet to to get the adaptor from them which connects to the Gaslow filler point, they also sell an in line filter. We have used this approach for three visits to Morocco and will use it again this year. We haven’t had any issues with oil/soot or the Butane problems you mention.
The plus side is that Moroccan bottles are very cheap.
Gaslow Braided Local / Reserve Gas Cylinder Connection Hose
The Gaslow Braided Local Cylinder Connection Hose simply screws into the Gaslow filler point and now you can connect any gas cylinder adapter that has a 21.8LH fitting to the Hose. Length 1.5 metrestouringoutlet.co.uk
Agreed, it’s too risky for us.I'm still a long way from plugging into their EHU's though.
Good luck with that, You can stop in what you think is deserted and still be pretty sure a Moroccan in a high vis will appear and claim to be the guardian . tbf they dont usually ask for much.Thanks nall - very helpful. Thing is we won't be staying on campsites much, but travelling around the country, also mountains and desert - so having the Truma running at night for heating if it goes below zero is probably not realistic with Butane, right?
Lots of "guardian" car parks to be fair. Generally all secure and only 3 to 5 dirhams a night and some have emptying facilities.Thanks nall - very helpful. Thing is we won't be staying on campsites much, but travelling around the country, also mountains and desert - so having the Truma running at night for heating if it goes below zero is probably not realistic with Butane, right?
This the way they refill European gas bottles in Morocco, Mauritania and Senegal.You should see the state of some bottles in Morocco. Bashed, rusty bottom rim welds broken. But you can if your lucky pick out the best ones.plus they are usually stored outside in the sun.
Note that the gas is maily butane so doesnt gas off easily if cold and it can get cold at night. There is usually enough to run a fridge but not to light the hob apart from 3mm high flames until warmed up in the sun.No chance for a grill.
