- Jul 26, 2018
- 47
- 34
- Pilote P696D
- Owned AutoTrail Navajo from March 2013 until replaced with current van in 2020
When I was researching my Lithium upgrade and deciding on which gear to use, I noted that several of the B2Bs also included the "battery master" functionality, but when I settled on going blue (i.e. Victron) for everything I forgot to check whether the Orion TR 12/12-30 did that, and of course it doesn't... After a slightly dodgy moment when trying to start the van I checked the engine battery voltage and realised my mistake!
After some agonising, and reading numerous opinions, I decided on the Ablemail AMT12-2 from RoadPro (using the Fun discount, of course) because I thought it was the most flexible, and I'm ex-IT so I'm not scared by complicated programming. However, the Ablemail appears to be in short supply at the moment, and RoadPro didn't receive their promised delivery last week, so I was wondering whether to cancel it and switch to a Van Bitz Battery Master instead. Particularly since I've discovered that the flexibility of the Ablemail requires either a fairly expensive Bluetooth adaptor, or a very expensive USB adaptor and software, the latter really only intended for installers, it appears. What does the Team think?
Meanwhile, I've been topping up my vehicle battery with a mains trickle charger (I'm on EHU at home), however the increased voltage from the charger resulted in my B2B thinking that the engine was running and hence siphoning off the engine battery's charge into the hab battery... I've stopped it doing that by temporarily pulling out the link to turn it off. Is this also going to happen when I wire in the Ablemail or Battery Master? I don't have a smart alternator, so the B2B's voltage sensing option seems to work OK, so I was lazy and didn't try and find a convenient D+ signal - must I/should I do that too?
Thanks, Graham
Thanks, Graham
