Where to locate my D+ signal
Northamptonshire, UK
AutoTrail Imala 625
Since 2014
I've just purchased a Renogy Dc:Dc charger to improve my leisure battery charging whilst on the move. The instructions indicate that, with a smart alternator, the D+ signal input on the charger should be connected to the alternator signal.
I have a 2021 Auto-Trail on a Ducato, so I'm assuming that this applies to my install, but is there a more convenient location to pick up this signal than going back to the alternator? Alternatively, can I just use the switched 12v supply to the fridge instead or is D+ something more than just an engine running switched 12v feed.
There should be a D+ connection on the fridge you could tap into. Not sure how Sargent electrics do but there is probably a relay box the D+ gets distributed from.
If you're struggling to find where you can tap into a D+ signal, then the easy option might be to use a D+ simulator which senses the vibration of the engine running.
Voltronic D+ simulator
Found this out from a very Knowledgeable gentleman on here who helped me with a similar issue. The D+ is actually for systems that do not have a Voltage Sensitive Relay. Apparently it is a low current 12 volt feed from the alternator switching on and off relays to suit. Therefore albeit 12v..its a low current feed only .
Kev(y);)
Reactions: 68c
Kev(y);)
Not quite as simple as that, it is a low current 12v feed direct from the alternator it is not designed to switch loads of relays. Motorhomes often have quite a few things switched by a D+ signal so they fit special relay boxes or simulators so as not to overload the D+ output from the alternator.
What model Autotrail do you have, it may have a split charge relay that will need to be isolated as well!
Reactions: Ver
There is a fused power distribution box i.e. the Sargent ec40 which is located behind the drivers seat. It provides a connection from the vehicle battery to the leisure battery system and has D+ switched circuits for the fridge as well as a D+ "booster".
There will be an existing arrangement to charge your leisure battery. Either a split charge relay or a small DC-DC charger. Whatever it is, it is very likely turned on and off by a D+ signal. So the D+ signal will be present at the distribution box, or at the existing DC-DC charger if there is one. There should be no need to go all the way back to the alternator.
If the existing arrangement is a split charge relay then as jwells says it needs to be disabled, if not it will simply short the DC-DC charger input and output, so it does nothing. If the existing arrangement is another DC-DC charger, then that probably needs to be disabled too, but may be OK to leave it connected.
make sure you do have a smart alternator, some autotrail requested non smart but none sure what date up to.
Mine was 2020 and was none smart, an autotrial imala
The D+ signal can be used to trigger the DC-DC charger, whether the alternator is smart or non-smart. It's the best and most reliable method of triggering. If it's a non-smart alternator you can get away with a voltage-sensitive trigger mechanism, but that doesn't work for a smart alternator because the voltage varies too much.
Since the D+ is already used in motorhomes to switch on the fridge while driving, and the existing DC-DC charger or split charge relay if there is one, then it shouldn't be a big deal to find a wire with the D+ signal on it.
I've got a 2021 Autotrail based on a Ducato. It has a standard (not smart) alternator and a Sargent split charge rather than a B2B.
I've recently fitted a Victron B2B. I removed the cab battery fuse in the main Sargent control unit to disable the original split charger. I anticipated having to connect to the D+ signal, but tried it first without using the Victron auto-engine sensing and it works a dream.
As soon as the engine starts the alternator puts out a steady 14v, and the B2B fires up a few seconds later. The alternator puts out 14v irrespective of idling, braking, accelerating. The joys of a non-smart alternator!
I don't know if the Renology B2B has engine sensing, but if it does give it a try.
Think you need to read it again Lenny? I stated it is a low current wire only. Did not state it will operate anything other than a low current appliance by that a relay or fuse board feed for a particular circuit. May just be the way you read it or it could be the way i may have put it possibly? ;)(y)
If it helps this articles describes the convertors socket and d signal.
Thanks Paul. There must be one I can get to but this is a useful backup.
Great information.
I need to access that panel. On my vehicle the supply fuse for the step and fridge are mounted just in front of it and I'm intending to mount the charger on the base of the drivers seat adjacent so it will be great if both D+ and the battery connection were so conveniently located.
Thanks.
Engine sensing isn't mentioned in the installation guide but Renogy seem to be pretty responsive so I can ask.
I must admit I assumed I've a smart alternator, but maybe I need to do more checking first. Keep forgetting it's really a commercial vehicle 😂.
Thanks.
I was hoping that maybe there was some standardisation and that a usable D+ signal would be in the same place in all similar aged Ducatos 😊.
Looks as though I'll be having some fun with a multimeter over the weekend.
The fridge fuse on my vehicle is mounted immediately under the OS door post, right below the location of the converters socket as described by HarryML, so I'm hoping it might be an easy find.
Thanks.
I'd (incorrectly) assumed my 2021 Autotrail Ducato had a smart alternator too.
See this thread I started a couple of years ago -
Thread '2021 Autotrail PVC - smart alternator?' https://www.motorhomefun.co.uk/forum/threads/2021-autotrail-pvc-smart-alternator.257871/
Have a look at the negative terminal on the cab battery. If just a plain connector and no shunt as in my photo then it's going to be a standard alternator.
Alternatively, see if the cab battery voltage changes using a multimeter (or a plug in USB cig lighter voltage display) when the engine changes from idle to acceleration. If it remains fairly constant then again it's indicating a standard alternator. Mine is rock solid at 14v when the engine is running no matter what load is placed on the engine.
That looks to be a simple check, and the install says I don't need to connect the D+ signal lead on a dumb alternator, so could be the original question is irrelevant. Thanks Barti Ddu
Thanks. I knew that box had the fuses for the fridge and step (took me ages to locate the step fuse when it failed). Didn't know it also had a D+ connection, but it now seems likely that I have a dumb alternator in which case I don't need to connect to D+.
Could be I've been seeking a solution to a problem that I don't have 😂
Personally, I’d still use the D+ on the B2B
Thanks autorouter . The Sargent PSU has an illuminated 'Charging' switch, but I'm pretty sure that's just for EHU. Might be worth a call to Sargent technical to check. They're usually pretty helpful.
Yes thats what I did on my autotrail Imala 735.
It sensed the signal no probem without D+
I guess the shunt is the little grey box on the - ve terminal then. Looks as though I do have a smart alternator 😁
