Hi I’m currently wiring a reversing camera and monitor , is there a ignition switched live somewhere within the dash I can use? This is a fiat Ducato 2019 model.
Thought of that but sometimes they are intelligent and don’t have the usual permanent live and switched. But I’ll check as that’s a good idea.I connected mine to the +ACC radio feed.
Yes that looks easier to do thanks.There will be one in the fuse box which is a cover with 2 Philips screws near your right knee if you were driving. Check out "fuse taps" on ebay to tap into a fuse ?
Changed my radio over to the leisure battery so now the red ignition live wire is spare, you can’t use it but I’m going to use it to power the fridge when on the move instead of the voltage sensing one which I believe is faulty. Mine also has a yellow wire which is permanently live. Probably useless information as mine is a 2012 Boxer.Thought of that but sometimes they are intelligent and don’t have the usual permanent live and switched. But I’ll check as that’s a good idea.
We used a piggy back fuse holder in one of the switched sockets in the "drivers knee" fuse box for our dashcam.Yes that looks easier to do thanks.
+1 to that (cig lighter) - very easy to get at the connections too. It's where I connected a USB socket for the dash cam.ciggy lighter is switched also the second power socket on Dash.
on our 2015 Ducato
Cliff
You are a star!! Thanks this is very helpful!!!!hadders
This is a picture of our X250 fuse box marked with the fuse position I used.
Just found a better photo of the fuse box connections.You are a star!! Thanks this is very helpful!!!!
