Where to buy a Lithium Battery?
Derbyshire, UK
Bailey Autograph
Since 2016
Just been googling them and prices are jumping off the screen at £1200ish for a 200ah one
My current battery is a Banner 100/110ah which is neatly hidden under the floor in the lounge area.
I want to just lift that out and drop in a lithium same size so I fully fill the space for max available power.
I am looking at all the other stuff which I posted in another thread re solar and chargers etc
Just thought quick question. What price should I / could I pay for one and from where?
Pictured below is the Banner 95751
Length 354mm
Width 175mm
Height 190mm
Just stuck a couple of the Aolithium 100 amp ones in mine, the company seems to be tied in with Amazon according to what is written on the user manual, the Bluetooth app gives information on charge, discharge, temp and other things but is not configurable. But for the price £249.00 thought worth a try.
https://aolithium.co.uk/products/12v100ah-lithium-lifepo4-battery
Fogstar don't do offers on lithium leisure batteries, but I've noticed the batteries have came down a little since last year. I've had one fitted for 6 months it's been fantastic others on here have fitted them and rate them.
Another vote here for Fogstar, I've had mine about a year now it's excellent 👌
Watching as pondering moving mine up to fogstar lithium soon.
2005 burstner with Victron Mppt 100/30 smart controller and blue solar charge controller. 400w solar and 3 110 acid leisure batteries
Am waiting due to battling Dometic re a faulty compressor fridge.
NO Not to Zero, down to 10% at best, zero is not good and will trigger under voltage (under what the set low voltage cut off is) 10.5 v I think
This is done to protect the battery from damage. If the battery were to continue to operate below 10.4V, it could be permanently damaged.
this may be handy
Another happy Fogstar customer. Swapped out 2 new x 100ah for the 300ah.
You can run them down to 11v ish with mild unbalanced cells. Proper balanced cells can go down to 10.5v without any hiccups or any negative effects.
I have fitted a 300a Fogstar Drift Pro recently and it’s great it comes with a plug in ballancer that you are advised to use every few months if required, with additional equipment you can become fully self sufficient without the need for EHU😊
Plug in balancer I never got one of those with my 300amp fogstar :(
No:( but thankfully my renogy dc-dc sorts balancing out whilst driving
