As per the title can someone tell me where the fuel pump relay is located on a X250 Fiat Ducato.
Ok ThanksEngine bay fuse box.
Thanks , i take it these relays just pull out for replacement and are not soldered in place ?looking at the engine, on the right hand wing. it is a red relay near the centre of the box
check out the ebay seller
the new steel filter is not backward compatibleI thought there was a new "all steel" version that was currently being advised. But hey, two of those should keep/get you on the road for a day or so ?
i have since changed Motorhomes but before changing i never found the relay , but i was able to cut of the fuel supply via cutting one of the four wires that lead into the top of the fuel tank at the inspection plate ( below/to the side ) of the passengers seat and then using what ever method you prefer , either a switch or relay ,, however be sure that the gauge of wire or relay is up to the job.Hello Bart, did you go ahead with the fuel cut off switch? If so I was looking to do the same and wondered if you had any pointers.
