Many thanks, I’ll have a look at the passenger side footwell. What do you mean by the inside base of the wheel arch?On my Carthago Compactline they use the passenger side footwell and inside base of the wheel arch. I have to lift the mat to reveal them. Could be different on the Malibu Vans but until last year they both came out of the same factory in Slovenia.
Thank you for you suggestion. The chassis VIN is on the windscreen, not a separate sticker that Carthago should have put somewhere else.Should be on the windscreen ?
The front wheel arch starts in the footwell, you may need to move some carpet or insulation. My Compactline might not be the same as your Malibu Van.Many thanks, I’ll have a look at the passenger side footwell. What do you mean by the inside base of the wheel arch?
You can’t rely on Carthago attaching the final sticker (as already mentioned). I was given it at handover because it came out of the document pack with the Certificate of Conformity. I was told to stick it next to the original one in the footwell.Thank you for you suggestion. The chassis VIN is on the windscreen, not a separate sticker that Carthago should have put somewhere else.
I would never accept delivery without a certificate of Conformity.I think this is what happened as I can’t find it anywhere, including with the certificate of conformity
I just hope that we don’t need it.
Thanks, so much for everybody’s help and suggestions.
