Where can i get a replacement unit!
Robert2891
Challenger Genesis 4
Two of my burners on my dometic weren't working so I decided to replace the jets. I first encountered stripped threads and had to drill the screws out!. Once the burners were off, I proceeded to remove the jets- however, when a little pressure was applied, the burners dropped straight through. There's a hole in the north position of each burner that I suspect should have held a bolt or screw but was absent. I've now got two burners that have dropped through the bottom - I've been able to remove the jet on the bottom left, but the top right jet seems to have had the edges stripped making it impossible to remove. Everything seems super corroded and I'm reaching the end of my tether. Any advice on how to resolve this very welcome, or where I can buy a complete replacement unit of this style!!
Thanks in advance,
Rob
You could try Magnums motorhomes but I’ve just had a quick look on their website and could not see the same one, they may have the spare parts though.
Likewise I cannot find anything close to this. I'm going to get some locking needle nose pliers to remove the other jet. If anyone can provide further guidance,would be most appreciated. Have just worked through repairing the diesel heater, boiler, batteries, solar and now this! Supposed to be going on a family vacation in 3 weeks and getting desperate 😒 still got the refrigerator to repair! Bought it off a real cowboy!
You could try heating the seized in jet with a miniature gas blowtorch which may help removal
I would fix the fridge ASAP and if you don't get the burners fixed you can always use a portable burner for your cooking (y)
