Where Can I buy These Plastic 22mm Connectors please?.
HYMER B644
Can anyone help me please?
I am trying to locate 2 x Push fit Tee fittings for 19mm plastic overflow / condensate drain pipe.
I don't know the brand, they were originally from HRP Online (they no longer sell them).
It is not solvent weld or water supply types that I need, it has to be this type?.
Anyone >?.......
I am trying to locate 2 x Push fit Tee fittings for 22mm plastic overflow / condensate drain pipe.
Anyone >?.......
Your local plumbers merchant?
They do not have this type
One of these? --
Sorry, they are 19mm
If it's only for overflow / condensate then your plumbers merchant will have something to fit even if it a different type of fitting.
If necessary seal with whatever you have around if it needs it, probably won't need it though.
Sorry it does say 22mm - have a search - they are available and nothing special.
NEW 2 X Plumbing Push fit Straight Connector 22mm Each FreePost.UK
I am in Spain, even with my schoolboy Spanish and a Friends fluent Spanish. Not a single merchant we have been to has them
Ah ok, realise you were in Spain.
Is there not a DIY store, it must be readily available somewhere
Think you are going to have to do a temporary joint with good old Duct Tape till you get home(y)(y)(y)
Hi Trev, go to the Roca shop and see Miguel it's heading towards the old town from Lidl and before Mercadona on the right hand side of that road, he helped us out with 18mm copper fittings, no on else had them. (y)
I asked is it normal in Spain to have 15mm 18mm and 22mm copper pipe, ;) he said nothing in Spain is normal. :LOL: Bob.
I’ve been there for my “Rollo de cobra”
Very helpful
