I fitted 30mm ones to the front of our ducato tuv approved more for the look than anything else but drive much better missing the self made tracks on the roads, quite a few manufacturers fit them as standard part of a axle widening package.Has anyone fitted wheel spacers to the rear wheels of a Mercedes twin rear wheel chassis to increase the wheel span and have they made any difference to the ride.
And when the wheels fitted they won't be seen at all.They is cool innit dude!!!
I’m def with you on this, I certainly wouldn’t fit them, but each to their own.And when the wheels fitted they won't be seen at all.
My view is they will put additional load on the wheel bearings.
The wheel design is so the wheel center is over the bearing, not inboard or outboard of it.
There tuv approved with a certificate just like air suspension and other approved add-ons can't get anywhere near the max front axle loads anywayI’m def with you on this, I certainly wouldn’t fit them, but each to their own.
Wonder how you would stand with the insurance company, if they caused an accident in any way.
TUV approved or not, it doesn't mean the bearings arent subject to an unusual load no matter what the loading.There tuv approved with a certificate just like air suspension and other approved add-ons can't get anywhere near the max front axle loads anyway
Okay I might have to replace the wheel bearings 2 week's early ain't going to break the bankTUV approved or not, it doesn't mean the bearings arent subject to an unusual load no matter what the loading.
Standard wheels will sit over the bearing producing only a downward force .
Sticking in spacers moves the wheel away from the bearing producing a downward and "tipping over" effect..
Here are the wheel spacers that Carthargo fit on the front of the Iveco chassis, they are also fitted on the rear from the factory but not sure if they are aware of premature bearing wear but I suspect they may have an informed idea.TUV approved or not, it doesn't mean the bearings arent subject to an unusual load no matter what the loading.
