What size inverter
Silver-Fox
Cheltenham Spa
Rapido
im a not so newbie
My dearest Daughter has asked me what size inverter she needs to charge her electric bike battery.
It’s a 750w battery and I don’t know what to allow extra for the initial draw.
She will be buying a Renogy inverter off Amazon.
Thanks all 👍
You need to know the chargers input wattage.
Whatever that is (on the charger label) then add at least 50%.....IE ..100w charger = 150w minimum inverter
Thanks all 👍
The mains Amps will be on the charger data label .. ask her for a photo of the label
..my e-bike battery is 1400wh .. and the charger draws 2A
2 A x 240v =. 480w
so a 500watt inverter would be adequate
she maybe better with a pure sine inverter rather that a quasi sine
Thanks for the quick replies.
I’ve already told her to get pure sine 👍
I’ll ask about the charger 👍
Doubtful Jim.
You haven't taken into account inverter losses and start up surge.
480w may be 2AH at 240v but it's 40 AH from the 12v battery
yes John am aware waiting for photo for definitive calculation ..
the charger input is 1.65A at 240 = 380 w
500 w inverter is adequate ..
when charging the inverter will draw about 30A from the battery.. charging tine say 4 hours = 120AH ..
unless she has a big battery bank, need to charge while driving ..
I bought one like this for my van to do that job
My bad Jim.
Confusing myself.
I was taking what you said your battery takes to be the answer to the question
This is the same charger as I have for our 750w Bosch batteries. I charge two of them simultaneously from a 600 watt PSW inverter and it never has a problem. The two draw around 16amps together, so a single one should be around 8amps. 500w will be more than adequate for your daughter
What you must consider is the lesiure battery capacity as she will be pulling 8 amps for up to three hours for a 60% depleted bike battery. And how she can recharge the lesiure battery?
Thanks for your replies.
She has two 100ah wet batteries.
1 100w solar panel.
I’m thinking if she gets a 1000w inverter she could run a small kettle of it now and again for a coffee etc.
She will charge her lap too off it as well so she says.
Personally I’d get a 12v charger for the laptop as I bought for my old Mac.
Thanks again 👍
Just a quick revival.
Any thoughts on a 1000w inverter so it could be used for a small kettle?
Is two 110ah wet batteries man enough for the job required?
Why not fit as big an inverter as she can afford/fit in the space available. That way if she ever changes batteries etc she won't need to splash out on a bigger inverter? I would be looking at he Renogy 2000W as a minimum.
As regards the batteries themselves, lots of Funsters manage with similar batteries until it's time to replace them, they just make sure they treat them kindly to prolong their life.
We have a Renogy 1000W inverter and this is great for running our 850W travel kettle and is so much faster than boiling a kettle on gas. Also works for my wife's travel hairdryer which I think is about 900W on its highest setting. We have two 100 Ah AGM batteries and they seem to be man enough for the job. It just sparks the solar controller from float mode into full MPPT charging mode!
With our setup I wouldn't go for a more powerful inverter. It would be nice to be able to run the 1500W air fryer but I think a 2000W inverter running that would take too much out of the batteries, so can only use the it on EHU. Maybe if I convert to lithium at some point, but the AGMs are only a year old having come fitted to our new van!
