RobPullen
- Apr 5, 2021
- 86
- 94
- Rollerteam 707
- Motorhoming since 2020 - previously in campers
I am looking to replace our mattress on our drop down electric bed as this is the one we use the most and the current one is so warped from body indents (its about 6 years old), even a topper doesn't help!
My concern is it is a basic fibre based 10/11cm (ish) mattress and fits quite neatly inside the bed frame, the edges not rising too high above it. My preference for prolonged use would be to fit a pocket sprung mattress with built in foam top, but this would mean it is at least double the depth at 25cm and almost double the weight. The overall weight won't be an issue, it will still be within limits for the bed (assuming we don't put on a few extra stone each!), but will affect payload to a degree and would mean the bed will return to a slightly lower position. We aren't huge so will still fit underneath without problem though. Can anyone foresee any other problems with this though?
Foam mattresses can be any size so more flexibility, but we could end up with the same problem eventually with it becoming distorted and uncomfortable. With busy working lives (well Laura not me - I'm semi-retired), comfort and getting a good night's sleep are two of the most important things to us when away.
So any thoughts? Has anyone replaced similarly or what options have others gone for with mattresses?
