I think if my van was 20kgs overweight I would not be the slightest bit worried. However I would be concerned about driving a vehicle class which my license doesn't currently cover. If it had happened in the past then again why worry about it now?
LARGE goods vehicle, not light.When did this happen? LGV used to mean LIGHT goods vehicle (under 3'5 tons) and the new PSV is called PCV Passenger CARRYING vehicle?
I think JR died. Van Weight Engineering are very good and half the price of SV Tech.We have a Globe car, up rated to 4250 Kg's, just a paper exercise, I also have my C1, it was a long time working it's way through DVLA, about five months, but you are able to continue driving whilst the application is being processed, provided you are not suffering any listed ailments.
The details for up rating are as follows:
J R Consultancy
Bury St Edmonds
01359 250808
01244 544598
nothing like reading nonsence into a sentence that clearly does not mean that.Hoovie
In your post (1st one above) you stated;
"If a van is RATED at 3500kg or less, you can drive it on a car (B) licence. It does not matter what it actually weighs"
This statement is wrong, flawed, and incorrect.
If the van has a MAM of 3500kgs, that is the maximum that the vehicle can weigh. Taking your statement at face value, you are stating that the vehicle can be ANY weight (including being over 3500Kgs).
Thank you for that.This was news to me until fairly recently as well.
Have a look at this .gov website page - https://www.gov.uk/guidance/general-information-assessing-fitness-to-drive . I include the significant parts in the rest of this post....
The key part is this:
"Drivers who were awarded a Group 1 category B (motor car) licence before 1 January 1997 have additional entitlement to categories C1 (medium-sized lorries, 3.5t to 7.5t) and D1 (minibuses, 9 to 16 seats, not for hire or reward). Drivers with this entitlement retain it only until their licence expires or it is revoked for medical reasons. On subsequent renewal or reapplication, the higher medical standards applicable to Group 2 will apply."
The way that reads to me is that as long as you KEEP your C1 entitlement, you fall under the requirements of Group 1
Group 1
Licences are normally valid until 70 years of age (the ’til 70 licence) unless restricted to a shorter duration for medical reasons.
There is no upper age limit to licensing, but after 70 renewal is required every 3 years.
But if you have it revoked, or let it expire (through choosing to not submit a medical at age 70 general license renewal), you are then subject to the same more stringent rules as commercial drivers as dictated in Group 2 (my emboldening)
Group 2
The minimum age for Group 2 entitlement to drive lorries (category C) is 21 and for buses (category D) is 24, unless the driver is undergoing or has passed the Driver Certificate of Competence (CPC) initial qualification which they can do at the age of 21. The Group 2 licensing entitlement is valid for a maximum of five years. Group 2 licences must be renewed every 5 years or at age 45, whichever is the earlier, until the age of 65 when they are renewed annually without an upper age limit. Shorter licences may be issued for medical reasons.
I do have a >3500kg MH, so need my C1. But even if I don't have that heavy MH at the point (not so far ahead ) when I would need to do the medical stuff to keep C1, I think I would still renew "just in case" to avoid having to do an annual renewal if I changed my mind later.
And for younger drivers (or maybe older ones who started driving later in life so took their test post 1996) and took a test to allow them to drive a bigger motorhome, the requirements of Group 2 will always apply (which could well be a surprise for them as they may well have assumed (fairly enough) that they are also part of the "renew at 70" brigade).
He gave up his C1 . So should be able to get it back....
If I happen to still have my current motorhome when I hit 70 (and I hope both events happen! ) then I'll apply for C1 retention for sure, but if I don't get to keep it, no biggie really either, just downrate back to 3500 and loose some weightThank you for that.
Reading the detail, I do agree with your analysis. And yes, it does come as a surprise.
Had it not been for the current turn-around delays, I might well have applied to keep the C1 - as you say - 'just in case'. But in my own situation, I'm struggling, in reality, to see circumstances where I might need it. In the unlikely situation the position changes ??, then annual applications it will have to be.
eat less cake and loose weight , that's what someone suggest for just 20kg'sI assume you mean this thread: https://www.motorhomefun.co.uk/forum/threads/weight-confused.252542/
You don't have a licence to drive over 3500kg but that's not the issue here as your MH is registered at 3500kg max so it needs to lose weight, assuming it was in full 'holiday trim' then you're only 20kg over so I don't think it would be difficult to lose that small amount ... you'll need to decide what you will miss less!
Are you aware that if you relinquish C1 and then later get it back the rules to retain are different? e.g. a medical and renewal on an annual basis after 70, not every 3 years?
Read this post - https://www.motorhomefun.co.uk/foru...3500kg-and-very-confused.252584/#post-4773401 - and click on the link to the uk .gov page.????
When was this introduced?
I know of certainly one Funster who applied retrospectively to get his C1 back after relinquishing at 70yrs and it wasn't demanded that he reapply every year.
Why should it change? Click on the UK .gov link in the posr linked above and send a question to the authorities that decide these things.Having no current medical problems except old age, I was led to believe that after I turned 70yrs old,
IF I wanted to retain my C1 ONLY, I would need a medical every THREE YEARS but
IF I wished to keep my full PSV & HGV, I would need a medical EVERY YEAR?
Why should this change if I want my licence entitlements back?
read the website page. don't ask me, ask the government. not my rules.You previously posted this (as part of the Gov.uk website,)
"On subsequent renewal or reapplication, the higher medical standards applicable to Group 2 will apply."
What has the medical standard required in obtaining the licence have to do with the period of time that the licence is valid for?
Don’t blame you either!!Just to tell the assembled Funsters that Colyboy has started another thread on this subject.
Like me, try to keep up but I'm afraid, as they say on Dragons Den, "I'm out!"
I have read the advice in the link which says that after your licence expires (age 70) the medical standard for a C1 go from Group 1 to Group 2. This means using the D2/D4 form procedure which has been posted about many times. I can’t see anything that suggests a change to the normal 3 year license. I know some unlucky people only get 1 year because of special health reasons but again this is nothing new. Where are you seeing this new 1 year license rule. I can’t find it.Read this post - https://www.motorhomefun.co.uk/foru...3500kg-and-very-confused.252584/#post-4773401 - and click on the link to the uk .gov page.
No, unfortunately that is not the case, Husband jumped through the hoops and the medical and got the C1 at 70 but only for one year, after a 1 year fight.The 'Higher Standard' of medical has nothing to do with the length of the grant of a licence. It is the class of vehicle
that would be a factor in the length of a licence.
In the case of C1, that is three years.
Don’t you mean, always strikes twice and starts 2 threads. That’s harder than just replying to his first thread - you have to admire that !colyboy is like lightening he never strikes twice
Nothing new there then.Just to tell the assembled Funsters that Colyboy has started another thread on this subject.
Or no payload.BUSBY.If you had it up plated you should easily be able for to downplays it back to 3.500 so your licence will be fine. You’ll just have less payload.
However, I got it for 3 years after a 9 month fight.
So why do we think that is, then??Nothing new there then.
I'm afraid Coly often starts a thread then rarely revisits it
Maybe he just forgets,like retaining his C1.So why do we think that is, then??
