Friends of ours are looking at Benimar motorhomes, they are unsure of the quality and build. Can anybody shed any information and views on them please.
Many thanks in advance
May we contact you; we are Kiwis buying a M286, would like to talk to you re LED lights.Hi, We are in NZ and have had a Benimar 202 on the Fiat for 3 months. It is great. A few minor items that you would expect on a moving home with power, gas, and sewer systems. Remembering Motor homes are not made in the numbers of cars, small commissioning issues should be expected.
Some changes we made: added a tow bar rated to 2000kg (easy to do as the Fiat chassis runs to the rear), extra LED driving lights in the lower blank spaces (easy to install kit from the UK), axle weighed and calculated the actual required tire pressure for the axle load and tyre rating is 51psi (down from 79.9 PSI) for a softer ride, carpet lined the storage locker to stop the noises while driving. We also reset the stop on the drop down bed to lower it further. Took out the spare and got a tyre slim kit with pump to remove weight and increase storage space.
