Wet rear bedding in a kontiki 625
Dickymo
Kontiki 625
Hi all im looking for possible answers to a problem that i fortunately found today the bedding in my kontiki 625 was wet directly under the roof light luckily it didnt get to the mattress the roof light is perfectly sealed and there are no cracks i put a hose directly into the base and could not get it to run inside but i think with a strong wind it could drive it up and over the drain channel has anyone had a similar issue
Thanks Rob
Thanks Rob
If it's a small Heki with one of those bars to close it, if it's not properly clicked shut it can be raised slightly in high winds which then enables some water to be driven in. Seems perfectly sealed until that happens
