- Apr 12, 2010
- 5,128
- 59,443
- Weinsberg Cara
- since 2007
Yes, at least that's what I was taught in welding school and what I've always done, however I've never seen the consequences of leaving them connected and something going wrong, if there were any earthing issues with the welding circuit it may cause issues with electronics in the van, maybe someone else has first hand knowledge of damage caused by welding whilst the battery earths are still connected.
I'm equally sure there is a lot of us who only do welding occasionally these days, that did not know about this, could you explain further please?These days there is a special box that provides safety whilst welding. It’s connected to both battery terminals.
Im sure the people doing the welding will know.
Called a shunt yeras agowith a device between than that he says, when attached to the vehicle battery, prevents damage.
Not good if the ecu ,bcm etc go 2 or 3k's worth to replace.Bugger a few fuses and electronics at the very least,
I've ever only known them called a 'shunt' .no idea what the proper term is?I'm equally sure there is a lot of us who only do welding occasionally these days, that did not know about this, could you explain further please?
Definitely the safest way to do it.Just a thought Phil but would it be easier and safer to unbolt the rack and be certain no damage will be done when welding.
Sadly no. The whole point of the welding in situ is to make the rack easy to take off.Just a thought Phil but would it be easier and safer to unbolt the rack and be certain no damage will be done when welding.
