Weight tolerances query
Al n Val
West Yorkshire occasionally
Rapido i1090 Distinc
since 2018
hi everyone
when I had my Rapido tag weighed earlier this year the weigh bridge operator knocked me for six when we were told we weighed in at 5380kgs 😱.
We were carrying approx 150kgs of water and i’d say full tank of diesel.
Now i’m being told (by a mate) that having 3axels there is a tolerance of 150kg per axel so my 5000kg weight can actually be up to 5450kg without being overweight and penalised.
Does anyone know if this is true or not as if it is it will save me £3500
Al
PVC
1995-2004 & 2017》
hi everyone
Al
If I am Reading this right, that means a 3500kg two axle van is really 3800kg???
Does not seem right to me...
Salisbury
Hymer B678DL A class
since 2011
He has a tag axle if you read the OP so he’s saying he has give of 5000Kg
Mid Bedfordshire
RS Endeavour
Just a tad..
It’s a binary offence Al. You are either under weight or overweight based on plate and DVLA records.
The punishment can vary. Sometimes tolerances are allowed, but the offence is binary!
Salisbury
since 2011
I am not able to confirm allowance but I would not be inclined to risk that much over as if stopped in the EU they may not have any tollerance and then you will be in an even worse predicament.🤔
dont own one yet.
Would it be wise trying a grumpy DVSA to convince about these facts or maybe a foreign official where they have a 0% tolerance , not worth the risk , it then also invalidates insurance as not road legal👍
PVC
1995-2004 & 2017》
Yep.... did indeed read OP.. And yep did see tag axle... please what significance off 3 axles and overweight against 2 axles... curious to your reply...
As carpmart says the offence of being overweight is, you are, or are not. Bit like a pregnancy test!
The subsequent action by whoever is weighing you is the important bit. Usually they will allow up to 5% overweight without prosecution ie a ticket/court report etc.
That does not mean that you would not have to remove the excess weight prior to being allowed to continue your journey. It is difficult to allow an overweight and therefor unlawful vehicle to continue to drive. What happens if you are then involved in a collision etc?
I’m not sure I’d like to ‘lose’ 380kgs at the side of a road somewhere.
bobandjanie
Javea, Spain
Pilote V600g
In my working life I owned and drove trucks, 44t and 6 axles still had fines exceeding weight, one fine in Dorset I couldn't find a solicitor to fight my case 2t under but over on one axle, they said the lady judge took no prisoners. 🤔
We went to court and I took all the paperwork proving the load was heavier than they declared, had I know I would have loaded the trailer to accommodate that. 😉
Still got fined but not as much, but more important was it never marked our operators licence. 😎
Don't take it for granted as with any offence you get nice policeman and some not so nice. 😁
Since living in Spain and losing sight in one eye I can only drive 3500kg weighing our van at touring mode including electric bikes fuel water food clothes we are ........... 3480kg . 🙄
Maybe a nice policeman would let us drop the 💧 . 😁 Bob.
Lenny HB
On the coast in West Sussex
Carthago Compactline
5% is often given as a tolerance in the UK but it depends which side of the be the officer got out or. Abroad no tolerance.
Weighbridge have a tolerance of +/- 100kg on a plate dynamic it's +/- 110 per axle so to be safe you need to be 300kg under.🤣
In practice modern strain gauges are very accurate
Salisbury
since 2011
We were talking tag axle and you were obviously talking about a max gross van of 3500KG which would be a totally different thing as you would be moving up your gross weight to a PHGV of which he already is.
He never mentioned 3500 kg the significance is that a tag axle combined gvw would be greater than a single axle £3500 was mentioned and I assumed that was to fit air assist suspension to allow him to uprate his already PHGV to a higher allowed GVW.
PVC
1995-2004 & 2017》
He never mentioned 3500 kg the significance is that a tag axle combined gvw would be greater than a single axle £3500 was mentioned and I assumed that was to fit air assist suspension.
Think we are at cross purposes here..
Salisbury
since 2011
Yes we’re discussing a tag axle being over weight and whether there is a tolerance allowed if stopped and could it be got away with?
I realise you were highlighting the issue of a smaller van however it’s as I say for those under the 3500 gvw it’s a change of revenue as well as overloaded axles and not worth risking it on advice from unofficial sources this applies to PHGV as well don’t you think🤔
PVC
1995-2004 & 2017》
Oki doki... change my 3500kg two axle van to 3501kg 2 axle van... as I said why just concern for tag axle??
Ridgeway
Lausanne
NiBi Arto 85E
Since 2012
5% in most of Europe and 3% here in Swiss. We breath in as we exiting the country…..
RandallC
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Don't quite understand how you got to that weight. Having said that don't know what Rapido and advised payload.
We had a Swift Kon-Tiki tandem axle with a MAM of 5000kG and failed to get near that even fully loaded with water etc for an EU tour, thats with a Honda PCX scooter in the garage. (used works weighbridge that was tested and cert'd)
Do you need a second weighbridge check elsewhere?
Would also agree with comments that its a binary situation, you're overloaded or you're not.
Sunny South Shields
Frankia Platin i7900
Since 2010
We had a Dethleffs Globetrotter tag axle at 5300kg went to weigh bridge and I was at 5600kg already had fitted rear air assist and was uprated to 5750kg.
RandallC
Devizes
A Class Rapido 8096
Gosh!
