haganap
- Dec 5, 2007
- 12,885
- 27,417
- Niesman+Bischoff 79e
- I'm an oldbie MH number 10
What weight has the tow bar been designed for, mine is maximum 100kg, should be a sticker on it.
No pal
Paul, me old mate....out of all the bikes being carried on a towbar mounted bike rack how many do you think have been checked for download.
Most won't even have been checked for axle loading.
Main consideration for nose weight is for trailers and caravans......tail wagging the dog.
bike racks don't wag, too short.
make sure all fixings are tight then just do it.
Yep....except, if theres no limit marked its either pre type approval or its not type approved.This.. if there is no limit written on the bar, you cant be over it can you..
I know people who have bikes on the A frames of Caravans, and on the Bar and pull a caravan too.Yep....except, if theres no limit marked its either pre type approval or its not type approved.
The first is legal, the second isnt depending on age.
Maybe I'm missing the point but if you:
... why do you need to know what the down force is?
- know the rear axle weight and are confident that you have enough spare capacity to carry the scooter on it
- have taken into account the additional overhang distance load (which varies dependant on the overhang of the scooter and rack from the rear wheels)
- are confident that the tow ball is sufficiently secured to the existing chassis and that it and the chassis are strong enough for the job you intend
Surely it is the combined weight of the tow bar, rack, scooter and overhang loading that is important rather than down force?
If your MH is the one in your avatar, which appears to be an Autosleeper, then I doubt if you'd have sufficient capacity on the rear axle for the above!
He wants to know how much down force can be applied safely ie before the bolts or the ball snaps off
Its the vehicle that has maximum downforce figures, not the tow bar per say, so all will be rated differently depnding on rear chasiss construction
As stated above some experts have settled on an average of 200kg for their hydraulic rack that rely entirely on the ball mounting bolts and have been fitted to every type of MoHo i can think of
Your opinion on "Experts" is noted
hadn't realised you wanted flavour of the month figures
Having never owned an Autosleeper MH I wouldn't know what they are based on so could have been a Merc and it could easily have been your current MH as you don't mention what you have, so are we talking about a standard van with a long wheel base etc, or a coachbuilt, or something else? What it is will effect forumites' answers but to be honest the only people who will be able to tell you are either Mercedes themselves (assuming it's a van) or an engineer who can check it out in the flesh, with not knowing what vehicle we are talking about it is pure speculation on our part.No that motorhome in the avatar is brand new at the time. The children are mine and their cousins...One of mine is a serving soldier and the others are all at uni so taken a while ago.
As said earlier the vechile is a 3.0l Mercedes.
Any competent structural engineer or tow bar fabricator should be able to check your setup and give advice about your proposed vertical loading and twisting forces caused by the offset load on the tow bar. They will then add a factor of safety of 2 or 3 to account for the indeterminate dynamic loading whilst the vehicle is in motion.
It's all about weld sizes/lengths, metal thicknesses/metal type and bolt sizes/high tensile etc.
I met a guy in Spain who carried a 100kg scooter on a tow bar and the tow ball bolts gave way. Mind you, the vehicle overhang was at least 3 metres so probably failed from repetative dynamic loading.
Our first motorhome had a towbar and rack fitted by the dealer. We had a Yamaha 125 two stroke probably 110k at most. When we took the van down the road it was the most frightening thing I have ever experienced, absolutely no steering control and very little in the way of brakes. Afterwards I found out that for every 12 inches past the back axle you double the weight of the bike to get the loading (axle I assume)
I carry a Honda Innova 125 on the towbar (witter 100 kg load ) and rack of my PVC,Bike is 100kg-rack 20kg and allowing for o/hang means about 175 kg on rear and - 50kg off front.(using mentioned graph).The towbar rack is upgraded by a 50x6mm arm each side bolted to rack and to chassis of van.I have tested on road and cant hardly tell it is on back at 60mph (which is my max cruising speed .)The rack is bolted on towbar by 4x19mm bolts.Still plenty of r/axle-van load left.Wouldnt like to carry any heavier bike on back which is why I got Innova .
