Weep holes
Paul101
fiat Mondial
Hello and thanks for the recent add it’s much appreciate, ive recently purchased a 1997 swift mondial and have noticed water ingress from the large window behind the drivers seat. I’m struggling to find the weep holes and also wondered if these windows are known to leak or have a bad reputation or not.
Any help or advice would be greatly appreciated,
thank you
Any "weep holes" will just be in the outer section of the frame as the seals are designed to not let water through to the inside, if you are getting water inside you need to look at the seals.
only sliding windows have weep holes usually hidden by little oblong caps on the bottom edge of the frame
Thank you for all your input , whilst looking for the weep holes I noticed a small crack in the plastic window sill frame, right in the corner and very hidden where the water was collecting. So have managed to fill with some silicon, fingers crossed and thanks agai.
