Webasto 2000 not working
kontiki
Good morning everyone. Please could somebody help. Webasto 2000 heater shows a fault code H07. I would be very grateful if anyone knows how I might resolve the issue.
There is no reference to it in the manual
Many thanks
Tom
Many thanks
Tom
You could try pulling all the fuses, there are three on mine although it is a different model. This forces a re-boot.
According to this an 07 fault code (no mention of an H) is a heater lockout, which can apparently be manually reset.
I took mine to a specialist in Plymouth who plugged in a laptop to diagnose the fault. You might find one near you - Webasto are widely fitted in yachts and boats so it may be a marine place like the one I used.
I had the same fault code about 6 months ago. I pressed something on the control panel which caused it to lock up. I did a Google search which gave me a reset procedure. I cannot remember exactly what it was but involved pulling the main fuse for a set period of time, pressing a sequence of buttons on the control panel then pulling the fuse again. I’m sure a Google search shall come up trumps…good luck.
