Weak gas hob
Laika ecovip i400
Hey guys!
I was wondering if the hob on my Laika can be upgraded to have more heating power.
It's a bit weak and struggles to heat up pans to a hot temperature.
Apart from replacing the hob completely is there anything else that you would recommend?
Luke
Stealaway
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Hey guys!
Luke
As above
You could try new jets or a new gas bottle regulator
meanders
Funster - Life Member
Ipswich, Suffolk
Eura Mobil Terrestra
Since 2004
Or. Is it a problem with the regulator? Our original van suffered like this and it turned out to be a faulty reg.
lukebolger
Laika ecovip i400
Thanks guys I will buy a new regulator and go from there 😁
UK
Self Build
I only have two suggestions/Questions.
Using Butane instead of Propane in cold temps?
Regulator on it's way out?
I would replace the regulator before doing anything with the hob.
