Our water filling container is knackered can anyone link to a good watering can, do you use food grade ones?
Got ours from Dusseldorf Paul, Malibu stand was giving them awayOur water filling container is knackered can anyone link to a good watering can, do you use food grade ones?
Is there such a thing as a food građe watering can..Our water filling container is knackered can anyone link to a good watering can, do you use food grade ones?
Yes we got ours in 2007 when we bought the first van in Germany just wondered if there was some super duper new fangled container now.Got ours from Dusseldorf Paul, Malibu stand was giving them away
Take a lot of them to fill a 100ltr+ tank...and expensive!!Full - from all good supermarkets.
10 litre standard water can with long spout found in most DIY shops or Garden Centre. The water will never be in them long enough to worry about food grade.
I use two so can pick up 20 litres in one visit to the tap.
Very difficult to pour into the water filling hole without spillage, even with funnel. The watering can has a long spout that goes into the hole and empties quickly.View attachment 994262
We use these.. not much bigger footprint than a watering can and they have the added advantage you can carry extra H2O if required.
The possible difficulty of getting water into my tank with these container... which incidently i have never experienced, very easy to empty container into tank with no drips or drops is easily overcome by the fact that, if required i can carry an extra 20 ltrs H2O.. You cannot !!Very difficult to pour into the water filling hole without spillage, even with funnel. The watering can has a long spout that goes into the hole and empties quickly.
Fully agree , we usually carry a Honda scooter on the back , so unless travelling to a location with known facilities , will quite often keep reserve water up front to evenly distribute the weight as our main freshwater tank is also right at the back. Never had a problem with spillage. Maybe some vans have a high external filling point though...The possible difficulty of getting water into my tank with these container... which incidently i have never experienced, very easy to empty container into tank with no drips or drops is easily overcome by the fact that, if required i can carry an extra 20 ltrs H2O.. You cannot !!
My pvc only holds 60l. Quicker and easier to do a couple of trips a day with watering can to top off rather than a faff to drive round to tap, unravel and connect hose, then empty dregs from hose and reroll before returning to pitch.If I had to worry about filling with a watering can I'd book a fully serviced pitch instead
I have 4 x 5litre i van for drinking but use them for filling also.Full - from all good supermarkets.
8 litre ones x 12 @78c a go here. Plus use them for filling keeps your steps up & park as far away as possible keeps you fit.Take a lot of them to fill a 100ltr+ tank...and expensive!!
