Water tank filling (1 Viewer)
Lesleyjh
Bexleyheath
Autosleeper Nuevo ES
Since 2010
New to being on my own and needing to do things I never have before, so I need help
The water tank doesn’t seem to want to fill.
I have a whale hose fitting. It seems to fill a bit then I can’t get any more in. The motorhome says it’s full 25%. Do I need to have the water tank fill option switched on on the control panel? It doesn’t seem to make any difference and switches back to off on its own. Could the hose fitting be faulty?
Feb 22, 2011
10,427
21,813
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I can't assist unfortunately as I just stick a hose in the filler neck and turn the tap on.
But if you give the make model and year it will help others with similar models who'll be along soon.
Manufacturers do seem to make life complicated
7,861
13,248
West Sussex
Malibu Van 640 LE K
Since 2003
Hi and welcome.
I have not used a Whale hose fitting but if you think it may be faulty you could stick the hose straight in the filler without it and just wait till the tank overflows. That way you should know it is full, if the gauge still reads 25% it could perhaps be a faulty gauge. Again I don’t know much about a water tank fill option on the panel but some motorhomes have a 25% fill position for travelling with a reduced load so perhaps a valve has stuck in this position, if it has I would expect water to overflow beneath the motorhome.
What motorhome have you got? Someone with the same make and model might know what is going on.
DBK
18,426
49,821
Plympton, Devon
PVC, Murvi Morocco
Welcome! :)
As suggested, just stick a hose pipe into the filler and see if you can get any more water in. The gauge might be faulty. :)
A and B in the Huzzie
86
44
Worcestershire
Auto Sleepers Burford Duo
Since 2018
On mine there is a link to the tank level gauge so that it shuts off when full. What I've found when there's someone moving around inside the van is it causes the water to slosh around and so trips the control on and off. You can hear the relay clicking away.
Ultimately it fills but it puts a strain on the hose fittings. I just turn the mains water tap down to ease this.
Maybe the control or relay are broken.
Lesleyjh
Lesleyjh
Bexleyheath
Since 2010
Thanks so far
I can’t stick. Hose in as I only have a whale hose fitting
The motorhome is an autosleeper Nuevo ES 2011
86
44
Worcestershire
Since 2018
Aha, mine is an Auto Sleepers Burford Duo.
For now can't you take the Whale plug and just aim it into the normal hose filling point. You might need the black fitting to keep the valve open; it looks like a Hozelock connector with a bit out the side.
138go
3,276
14,616
Carthago 138
Since 2001
You cannot rely on the gauges as they get their input from sensors in the tank that are notoriously unreliable. Most of us have a petrol tank like filler and we just us a hose or watering can. Yours was designed by an ardent caravanners who expected you to carry an Aquaroll round with you and an external pump to pump it into your water system. Miles to complicated. If you get stuck anytime you can fill the tank from inside by undoing the inspection lid on the tank. Think you will have to look at how others have solved the problem.
Reactions: DBK
Lenny HB
55,856
162,948
On the coast in West Sussex
Carthago Compactline
:welco:
Water gauges are notorious for being inaccurate and playing up.
have you taken the inspection cap off and check how much water is actually in the tank?
7,861
13,248
West Sussex
Malibu Van 640 LE K
Since 2003
:welco:
The last Autosleeper I tried to help with a problem didn’t have an inspection cap on the waste water and I am guessing the fresh water is the same. Inspection caps may be something we owners of German motorhomes take for granted but not sure about UK ones.
Jonno1103
1,411
1,577
Harrogate
F Line F70
Since 2012
From what I remember... it's been a while... the system is fully electronic and has two pumps, external (superfil) for filling from an aqua roll or similar and internal (inline booster pump)... you need to make sure you've selected the correct one on the panel. It's also tends to be a two person job as the panel tends to switch itself off after a short period as the filling process on the A/S and Bailey's is so convoluted and slow (and a reason why so many with this set up go back on the forecourt) so you need one person in the van and one outside.
The internal pump is also governed by an inline pressure switch, any fluctuation in the water pressure whilst filling will turn everything off.
Using the the superfil, check the contacts on the van body and the block, if they're looking a little weather beaten give them a rub with the rough bit of a match box or a nail file/emery board.
Sorry but everything else is basically a garage job especially as the issue maybe air getting into the pipe joints and a full inspection maybe the only option.
The system was essentially designed for caravans without onboard holding tanks and many builders who construct both platforms use the same system to save money even though it's not really practical on a motorhome.
You then have switched (powered) taps to contend with and tap filters... which invariably clog.
This plumbing set up has always been a deal breaker for me regardless of what discounts are offered or the quality of the internal finish.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
I always lift seat open inspection cover when filling can see how full it is - still use exterior fill point just dont get airlocks now - watering can or hosepipe
913
663
Cotswolds
Bailey Approach 625
Since 2011
I have had two MHs with the Whale systems, they were implemented differently, neither were an Auto-Trail so I can't be specific.
Suggestions:
1. ensure the connector is fully connected to the MH. Lift the flap fully to the vertical position, insert the connector, if its fully home you will be able to lower the flap to the horizontal position. This will trap the connector so it remains connected. (lift the flap again to remove the connector when finished)
2. trace the pipe from the inside the MH to the tank, its probably in the cupboard or under a seat. See if there is a solenoid valve in the pipe this is the full implementation so that the hose can remain connected on site and the tank will refill automatically when to use water.
3. If a valve is fitted try emptying the tank and see if you can refill it, does it stop again at 25%?
Good luck and welcome.
thebriars
1,149
2,182
Teesside
Since 1990
Some systems have an option of just filling to 25% to just give enough water in the tank whilst en route. Could it be anything like this that has been enabled?
138go
3,276
14,616
Carthago 138
Since 2001
Rube Goldberg machine. The art of making a very simple task as complicated as possible.
You really would not have thought they could make filling a water tank so complicated. The solution is so simple. Watering can or hose.
ymfb
798
6,347
Salisbury
AS Kingham
Since 2009
Our AS Kingham will only allow the Whale part to open and start filling when the electric is turned on. When the tank is full the valve should close, ours doesn’t do that bit quickly.
Ours often says the fresh tank is 25% full, when it isn’t.
Hope that’s of some help
77
61
Beaumont-cum-Moze
Autosleeper Burford
A class American RVs and C class over 50 years
77
61
Beaumont-cum-Moze
Autosleeper Burford
I have a Autosleeper Burford and I had the same problem,The cause was in the filler connector under the cooker there is a very fine wire filter that blocks up,its easy to rectify but awkward to get at.Wherever yours is it will be directly behind the filling point.all the connections are push fit so easy to dismantle just make sure you put the 2 wire electrical connections back on the right way.
