Water pump running on, noisily
DaveHobson
Bristol, UK
Bailey Advance 66-2
Since Sept ‘21.
More water pump woes! In our Bailey Advance, we have a submersible pump. It’s normal for it to run on a bit after use (to maintain the pressure in the system, I think?), but recently it’s been running on for ages, in fact until we switch it off at the control panel. Then, when we switch it on again, it’s fine. It doesn’t happen every time, but when it does, the ‘running on’ noise is louder and more rough-sounding than normal. The pump is not old - 2 years I think. Any ideas?
Sounds like you have a pressure switch inline with the pump if so it just needs adjusting, need to let us know what make it is.
If you look under the taps there will be 2 wires going to them if it's a non-pressurised water system
If it’s a Whale pump, this may help
