Water pump problem
rollerteam 746
The water pump in our rollerteam 746 works when you first switch it on but if you go to use it again after 10 minutes it will not wrk . However if after I first use it I switch the power off and then switch it back on next time I need it it works . Only just started doing this any suggestions?
You can adjust the pressure switch on the shurflo pump with an Allan key so I’ll give it a try tomorrow.
Mike
I was on ehu at a site so will test at home tomorrow. Thanks
Do check the strainer if you have external pump. Could explain works, clogs up and stops?
It turned out to be a loose connection in the distribution box thanks for the suggestions 👍
