Water pump equivalent
Auto Trail Savannah
Hi,
I currently have a very noisy shurflo 4029-181-A32 which I think is on its last legs.
I understand Shurfo don't make them anymore. Has anyone found a relacement?
If so Name Rank and Serial No. please.
The only pump I've found is 20PSI (4029 is 30PSI), 6.8LMP (4029 7.5LPM) and it draws more current.
I think the Shurflo Trail King 7 is available as a 30 psi. Not sure if the flow rate is suitable.
The cheapest I have found at 30psi, but there may be added shipping costs, in which case, this one on Ebay may be the next choice using the discount code. (y)
Jock. :)
Note that you want to size your pump to the system it was designed for. More isn't always better. An oversized pump might need to pulse more and be louder. Increases in pressure might feel a bit better at the tap, until you empty your tank twice as fast.
