Hi to every one, I have just joined this forum, And I need help straight away.
I am rather new to owning a motorhome, went away this weekend and all was ok.
However when I turned on the tap the water pump did not kick in, I eventually found that the fuse had blown so I replaced it and all was ok water was running fine. when I turned the tap on again the fuse had blown again, this happened several times until I got fed up of replacing the fuses and gave up on it. Does anyone have an idea what the problem could be and what I can do to put it right.
with D.I.Y I am pretty handy, if anyone has some advice That would be great thanks.
My motorhome is a 2003 fiat Ducato Bessacarr E740. Thank you All.
