Water pressure again
West Midlands
Laika Ecovip 309
since 2011 but years in a caravan
I'm really getting fed up with my water pressure in my.
Two years ago we had the (not sure what it's call) the thing that has a diaphragm it in to keep the water pressure constant leak and AEG replaced it. Last year we had the water pump replaced by them, this year it does not matter how much I bleed the taps I cant get the air out the system and the pump to stop.
No water leaking anywhere I can see.
I have booked it in to AEG again and they want £115 to look at it when they can fit me in, in one and a half months.
I said if the pump you fitted last year is faulty ad it's still under warranty will you still charge me and they said yes.!!!
More likely to be air getting in than water out,check that the filter bowl hasn't got a crack in it.
In ours although drained down, the filter bowl had been pushed half off and cross threaded but luckily not cracked but leaking air.
Took it off and screwed it back on and it was fine.
