Water Dripping outside of Van
Hampshire
Dreamer D68 Ltd
Since 2020
Hello Everyone
We are away in the New Forest
Today I have noticed water dripping underneath the Van! It is under the area of the sink/fridge drivers side . See photos and video.
It is not the frost switch as I have checked this?
Any ideas please?
Regards John
MH is a Sunliving S60SP 69 plate
  • FullSizeRender.MOV
    3.6 MB
Boiler breather or fridge condensate or waste water connection? Sorry best I can do 🤞
You could simply have sprung a water leak on a tap or a drain and finding the easiest way out the van.
Did you drain down the van over winter - has any bits been frozen?
It is unde
It is under the fridge area The fridge is working ok though
Could well be the condensate then
Put a glass under it and see if its clear.
Our you could pop some food colouring into water, red wine etc and tip into the fridge drain , see if it comes through
Yes that could be the problem. We have used the MH two weeks ago and there was no problem. We are having a HAB check in a week so I will ask them to have a look for us
My Motorhome mending skills are not very good😂😂
It could be a pipe leak as Mrs W has just said the water has run out!!!
Maybe you didn’t drain it down completely over winter? Small crack somewhere or joint not sealed.
Like the look of your lovely scruffy dog!:giggle:
His name is Archie. Nearly 14 and is Blind as had to have his eyes taken out because of glaucoma ☹️
Could just be general condensation if you've had a very cold night. Is it continuous or does it dry up during the day?
