Water bottle bendy pipe spout thingy.....
Leicestershire
Autotrail Apache 634
Since 1998
I'm looking cap for a 10 or 12 litre water bottles which has a bendy pipe for pouring water into the water tank more easily. I've been using a funnel with a bendy pipe but it makes it a 2 man job, one to hold the funnel while the other pours. Do such things exist and if so where can I find them please?
Keep it simple!
Covers all eventualities. We call it Nellie, and goes everywhere with us😉
After years of struggling with a bendy funnel, I got a tip to use one of these. Fits perfectly and no need to play balance the funnel at all. Very cheap at around £3 squiddlies
What i use also
Re your funnel.
How about drilling a small hole at the top of the funnel, adjacent to the lip.
Insert a split ring through the hole and to the ring attach a small sucker.
Stick sucker to side of entry point of water and pour away.
Cross my palm with silver and I might be minded to post a photo.
Another vote for the PaulandChrissy solution. Works a treat.
I did say to clean out the container.
Geoff
You did, but how clean can you get it? It's not food grade either so although it may be ok for topping up immediately as the water would only be in it for a short time I wouldn't want to keep water in it to top up the tank later.
I’ve made a blog with the help of my daughter of all the different funnels I’ve designed if anyone would like to take a look. Link below.
Cheers PaulandChrissy
If you've cracked it, you might need some repairs :rofl:
I'm sorry but how can a funnel be faster to pour than a watering can , no need for any pipe just shove the nozzle in and pour.
Because the pipe on my funnel (I cut the pointy end off) is a lot wider than the spout of a watering can. Plus I don't want to add anymore large items to my already quite full storage area. Some great ideas in here though and all much appreciated (y)
I’ve got a small 3d printed funnel that just fits in the filler hole and stays in on its own. My son found made it from a program he found on line. The mouth is wide enough the allow air out for fast filling.
