Waste pipe
Wellington
Leicestershire
Carthago Compact 138
I am merrily carrying standard convoluted waste pipe, and have just discovered it doesn’t fit my outlet. It’s a 25mm outlet with an internal handle to dump (so no visible tap). If I order 25mm wobbly pipe, will it fit, or is than an internal diameter and I need some sort of adapter thingy?! I don’t anticipate using it very often, but like to keep my waste empty whenever possible.
Never had one and never needed one, although we never stay on site's. I always drive over the waste outlet.
I cobbled together some plastic pipe fittings to attach a hose to our waste outlet. It wasn't perfect but it worked. Then I discovered that Dethleffs can supply an adapter that fits onto the pipe outlet.
I had a similar conundrum and visited a garden centre, pond section,tape measure in hand.
They will cut a piece to any length you need.
I used a washing machine drain pipe extension hose. It's about 25mm, and has a rubber conical bit at one end that is fairly flexible and will push over a 25mm pipe outlet.
I bought a corrugated hose that turned out to be a little bit smaller than my waste outlet pipe so I just wound some duct tape around one end. It’s now a good snug push fit. Its never let me down in 10 years usage.
Ian
