waste overflow
Burstner Tstar695
We have a Burstner Tstar695 and our sink waste water is coming straight out of a small pipe set high up behind the rear nearside wheel rather than feeding into the waste water tank? Anyone else had this and do you know why it's happening.
The obvious answer would be that a pipe joint has either split or come loose, as it should be feeding your grey waste tank. Time to get dirty and get under your van with a torch. I don’t know your van but if it has a double floor you may need to a professional if your not handy
w2f
Don't know your van either but it does sound like a waste pipe joint has popped off.
Check if it's same happening with sink shower and basin. That might give you an idea where the leak is if one is draining correctly.
After that it's tracing the pipe and checking joints
i cant see why there would be a pipe connected to the waste terminating in the wheel arch with an open end can you trace said pipe internally?
If it is waste water, it's probably just tracking along the same route as the overflow from the boiler and just appears to be coming out of this pipe.
That's my thinking anyway
Maybe it isn't grey water at all but fresh water because the boiler drain/frost valve is open.
Very possible, but I'd assumed water was coming out the tap, down the plug hole and appearing under the van ?
If it was the frost valve I don't think any water would come out of the taps
Have you got the valve closed on your waste pipe?
