warwick xl 2025 noise
bri
South Yorkshire
BENIMAR BENIVAN 122
hiya everyone,new warwick xl 2025 ,the noise when travelling ,even on the best road,is horrendous.we have tried packings and cushionings but it seems to be coming from cooker side of van but cannot stop it or quieten it.desperate for a solution.
Are you running empty?
Do you know what your axle weights are?
Are your tyre pressures set to correct pressure /axle weights?
Try taking it for a drive with nothing removable left in the cooker, ie the shelves, grill pan etc.
Good luck! Your dealer might even be good enough to help you out!
It may take some time!
What sort of noise, road, rattles, squeaks, engine, cupboard contents ?
more like rattles!weve taken things out and re-arranged things but its definitely on left hand side of van.we are aware that you are always going to get some noises even in a new van,but what we have got is absolutely horrendous.
That doesn't sound right although I've no experience of the motorhome you have, I'd take it up with the supplying dealer
Is it on side of the cooker? If so as previously said empty cooker right out shelves ect, then put tea towel under lid that sometimes helps 🤔
The pull up flap to the right of the sink on mine rattled, tried everything to stop it in the end I got new hinge things that clipped in properly no more rattle
One of you drives, the other wanders about in the back to identify where it's coming from
(is it legal to be wandering about in the back? how do you get up to go to the loo on a coach if it's not?)
