Just driving through France & a flashing red oil can warning light has come on & with a message to "Change Oil".
The manual says this is "EXHAUSTED ENGINE OIL": It then states "if the warning light flashes, this does not mean the vehicle is defective but the oil needs to be changed as a result of regular vehicle use.
I have checked the oil level with the dipstick & its between the min/max level & looks clean. It shouldbe as I had it serviced last month.
The manual then states "If the oil is not changed the engine operation is limited to 3,000 rpm when a second threshold is reached & limited to 1,500 when a third threshold is reached. Which obviously will be a problem!
If in the UK I would take to my local garage but a bit more challenging for me in France.
Anyone had a similar experience & if so what was the solution?
