wardrobe light fault ??
All over Europe now
Adria 680ST Gold
wardrobe light not working , 12v is present and bulb ok removed possible bad switch and conected bulb onto 12v feed but still not working ??? have 4 spare bulbs but none working when connected to the 12 v wire ,,, ???? makes no sense good bulbs good 12v but no light ???
Duplicate thread?
Check the magnets are still attached to the doors on the inside of the door. The switches work off breaking the magnetic field, if the magnet has come off the door and stuck on the switch it wont work
Do you check the voltage at the bulb while it is connected? If it's there the bulb must be faulty... Or multimeter faulty (unlikely🤔)
