Your 75/15 is rated at max 220 watts.hi i have a 280ah lithium and a 75/15 victron mppt controller there a 100w panel on my bailey autograph at the moment my question is what panel should i get to upgrade please
hmm thats worth a thought unless some one takes a fancy to it while your awayYou cannot have too much Solar..however you can...depends on roof space and cost...
But when you go down the route of adding more Panels, you then need somewhere to store all of your harvest.
Being more flexible and more efficient you could buy a freestanding panel which will harvest and out perform your current 150w Panel when you experience a low in the sky sun and you can move your panel to a position that's most beneficial..
I use mine from sunrise until we go out on bikes...then again in the late afternoon...the yeald is amazing compared with flat roof mounted panels..hmm thats worth a thought unless some one takes a fancy to it while your away
More like around 10 amps in ideal conditions so it would be fineThe largest one that space, budget and weight allows?
More solar - more harvest.
More batteries - more stored power.
Be warned your solar at 75/15 can only handle so much solar. 200 watts is capable in ideal conditions of over 15 amps?
