Sterling Power 100Ah Lithium battery, Votronic 25A mains charger, Votronic 50A B2B
Run battery down to BMS shutdown, set to low volt 10.8v (I know it can be set to go lower than this). B2B would not waken it up despite saying it could!
I have a Ring Power Pack which I believe can waken it up, by applying its 12v output to lithium terminals with engine running, it should switch back to life and accept charge. But since the battery terminals were showing 10.8v, if I apply the power packs 12v I end up with 22.8v at terminals, potentially shutting down BMS by over-volts shutdown? Am I over-thinking this/wrong? Or maybe the capacitors in BMS were holding volts high but it would seep away to almost zero?
(It is going again, the mains charger started it right away, but if this happens off-grid I'm stuck!)
