Waeco reversing camera
Bessacarr E435
Hi, We have a Bessacarr E435 with a waeco reversing camera at the top of the rear of van, only problem is we've put a box on the back and camera just looks down on the box! Does anyone know if we can adjust the camera on the van to look out a bit? Tia
Hi Claire, which type of waeco camera is it?
I would be very surprised if it cannot be adjusted.
Some are a ball eye type which can be moved in its socket and some are on a side to side bracket which have a small securing screw.
Ahh, I don't have the model number, but this is a pic of the camera
I think you will find that the high level brake light screws also hold the reversing camera cover in place.
if you remove those screws i believe ( but not completely sure ) that will give you access either to remove the camera cover or to the camera itself. also the camera cover may have a velcro location strip at the bottom which you will have to carefully prise apart.
you should then be able to adjust from there.
if the aperture in the moulding is fixed you may have to adjust it so the camera can see the angle you require.
